Ok, I'll just put things down in the order that I remember them. This is not a good service post
From my old Lightning Yellow
1. I got a recall letter from Vauxhall saying that the airbag needed to be replaced. Booked the car in stating airbag recall. Drop the car off and phone back in the afternoon expecting the car to be ready, but no, they are 'waiting on a part sir'. Hmmmmmm, I wonder what part that could be? So despite having about 3 weeks notice that it is coming in for an airbag (they generally have 3 weeks at least between me booking and the car going in as I need a courtesy car as I live about 8 miles from the dealer) they failed to order one in. The car was off the road for 2 days because of that
2. During the summer I had 2 problems with the car - the heater not working and knocking coming from the steering. Parts were ordered in for both and my car was re-booked in. Come the day I drop the car off, pick up the courtesy car only to be rung at 10am at work to be told that actually the part isn't in, and there's nothing they can do to the car
3. The next time the car goes in a coupling in the steering is replaced and the heater was supposed to be fixed. Then they say the part needed for the heater has been 'sent back accidentally' so no fix again. This is approximately 2 months after they had ordered the part for the heater. The coupling doesn't fix the steering problem, but for once that isn't their fault
4. New steering rack ordered and car booked in. I drop it off and they warn me it will be a few days off the road. When I pick it up a few days later they have finally fixed the heater and done the steering rack. But in the process the instrument panel has been scratched and the stalks have not been put back on properly. Oh and the small matter of them not noticing that the steering wheel is on straight during the 13 miles they have put on the clock
That's all I can remember for the LY other than one case where they kept the car in longer than they originally said and I was going away for a long weekend and stated that I'd just have to keep their car. To which they got pretty arsey and demanded I return it. Frankly it's not my problem if they haven't got my car ready
Turbo:
1. When I got the car it had a seriously leaky boot. Leave it parked facing uphill in the rain and the boot would get soaked. The problem was very obvious - where the boot seal joined at the bottom end of the boot there was a hole and water was getting in there. Plain and simple it needed a boot seal. I booked it in and even got the guy to come out and have a look at the seal for himself (who incidentally was telling me how he was trying to 'do donuts' around a roundabout in one - not likely to be his car). Did the usual of dropping the car off and picking up a courtesy car. Rung back in the afternoon to be told (you've guessed it)....... waiting on a part. This was a Friday and they told me they could get it in for next morning and I could pick it up on Saturday. Funnily enough that didn't happen, and I kept getting the same until I eventually got it back on Tuesday. What really annoyed me was that they had asked me 'is there anything else we can have a look at' so I told them to check the stereo front that was not flipping properly, sagging hood that needed adjusting and most importantly dipped headlights that were so badly adjusted I could hardly see a thing and were bloody dangerous. The car was also filthy when I dropped it off. When I came to collect they had done nothing but the boot seal and blamed the computer system for the fact that nothing else was done. The car was also still filthy, which I would have no problem with had it been done same day but they'd had it in for 3 1/2 days and still not found 30 mins to clean it. Oh and another 10 miles on the clock
2. It went in again recently after the passenger window wouldn't go up properly. That was allegedly 'fixed' although the problem came back within about a week (or 3 winding downs of the window) but luckily freed itself again. The window still doesn't seal properly at the windscreen end though, which was fine before
3. The last time in went in was a couple of weeks ago for a new seatbelt. That seemed to go quite smoothly for a change but they mentioned something about needing the car back in for some trim clips they didn't have (I've heard nothing) and a few of the remaining trim clips have fallen off
4. Having washed the car at the weekend I noticed the boot seal had come apart again and I was getting a wet boot. This time I've sealed it myself as I'm fed up with them touching the car and making things worse
It has got to the point now that I would rather put up with a problem than have them try to fix it and cause a host of others. I absolutely hate using them but have no other choice due to practicalities of getting the car to and from dealers
And yes, if someone from Stevens is reading this you seriously need to get your act sorted out as this level of customer service is totally unacceptable. You can contact me if you need
Having spoken to other VX owners that have used Stevens Crawley it seems my experiences are unfortunately the norm rather than the exception
