I'll probably give that a go - any idea what I should re-stick it down with?@TT - my boot seal is round the other way compared to yours, join is nearest the engine - may be worth a try for your leaky boot seeing as it would suit the incline of your driveway
A
Stevens Vauxhall Crawley and Horsham
#21
Posted 03 June 2005 - 01:47 PM
#22
Posted 03 June 2005 - 02:40 PM
Stick? I thought they were pushfit?I'll probably give that a go - any idea what I should re-stick it down with?@TT - my boot seal is round the other way compared to yours, join is nearest the engine - may be worth a try for your leaky boot seeing as it would suit the incline of your driveway
A
..heres what I would do. Get some double sided stick tape and peel off both sides. Lay it on the edges of the metal that the seal goes onto and then push the seal into place sticking tape to seal, and tape to body.
Or just put a few blobs of silicone sealant at several points along the edge.
A
#23
Posted 10 June 2005 - 06:14 AM
#24
Posted 24 June 2005 - 08:27 AM
#25
Posted 24 June 2005 - 10:38 AM
#26
Posted 24 June 2005 - 10:40 AM
#27
Posted 24 June 2005 - 11:29 AM
#28
Posted 24 June 2005 - 12:16 PM
The independent engineers report has absolved me of any responsibilitySo you did manage to kill off a peice of my car just by sitting in it. Lucky I don't have a turbo - probably would have run out of oil
#29
Posted 24 June 2005 - 05:26 PM
..tis true mate - was quite lucky apparantly!Saw your car there yesterday. They told me you had three bolts missing!!
Incidentally, I already mentioned my coolent bottle sprung a leak on the way to Le Mans (Well, at Dover before even reaching Le Mans to be honest but that's another story!!)
Well, called up on Tuesday, they ordered the part, took the car down there on Thursday - job done by 2.30pm. No problem.
Cheers,
Adam
#30
Posted 24 June 2005 - 05:32 PM
Yes mate, this was Horsham. £220 does seem a bit steep, what was on the invoice? New sparks? Any extras?This is from Horsham right? I would be very shocked if you got that level or service from Crawley
Had mine serviced by Horsham on Monday 13th and was pretty pleased with the experience - not cheap at £220 for the 20k service but I felt the standard or service was higher than Crawley
The real test is when it goes in for 3 days on 11th July to have the alternator pulley fitted, a new windscreen seal and the coolant bottle replaced as bizarrely mine sprung a leak in the same place as Ben's when I got back from Le Mans
Shouldn't be a problem, they did all my work in 1/2 a day - just had to wait about for the replacement bolts.
Adam
#31
Posted 13 July 2005 - 09:11 PM
#32
Posted 13 July 2005 - 10:12 PM
I fairness mate, the fact they ACTUALLY fitted a new seal is merit enough surelyThey don't get 100% as yet because the new seal has not been tested yet..... but otherwise good (for a change!)
if it leaks again they cant deny responsibility, so thats gotta be a thumbs up
#33
Posted 15 July 2005 - 06:38 AM
Told you matePicked mine up from Horsham today - for the first time they get a
Firstly they said it was fine to pick up the car up until 7pm as a salesperson would be there. Small but a nice touch
They have done everything I had asked - new windscreen seal, which looks pretty good (though only had time for a fairly quick look), alternator belt is no longer squeaking, and a new coolant bottle. I think they have also adjusted the passenger window but I'm not totally sure. This is a new experience for me as no matter what I asked Crawley to do, something would be missed. They also had time to wash the car and clean the inside plus they actually gave it back to me when they said they would (again a new experience after Crawley)
...I made sure that the gang there knew I was a fussy bugger from the off, and told them the tale about me being banned from Crawley Audi after making a scene in their after shoddy service - a round-a-bout way of letting them know I'm not to be f*cked with lol
My only gripe with them is that you have to wait for bloody ages to get a courtesy car out of them, other than that v pleased!
Cheers,
Adam
#34
Posted 17 August 2005 - 07:35 AM
