A Few Words (or Pictures) Of Warning....
113 replies to this topic
#41 Guest_AntB (Guest)
Guest_AntB (Guest)
Posted 25 February 2006 - 03:43 PM
another one on it's way out been replaced :(
the removed tank looked like this:
doesn't quite show how bad the crazing was, i've been losing coolant like nobody's business :o
the lovely new one looks like this:
some numptie at lotus obviously thought these were a good idea:
called me old fashioned, but i prefer these:
might be an idea for people to replace the crappy clips with jubilee clips, i assume the only reason that they're fitted to cars is due to cheapness... they're fcuking sh1t! :beat:
#42 christurbo
christurbo
  • 3,784 posts
  • Interests:My Civic Type R
    My Black Beast of a VX!!!
Posted 25 February 2006 - 05:51 PM
Had all my hoses [front] and expansion tank replaced on warranty. thumbsup
#43 Shep
Shep
  • 802 posts
Posted 18 March 2006 - 11:46 AM
Ding!
  • Attached File  tank.JPG   114.88KB   1 downloads
#44 Eagerbeaver
Eagerbeaver
  • 62 posts
Posted 18 March 2006 - 02:41 PM
£20....got it three days later thumbsup
Could you tell me where you got yours from, yes I know I can get it from a VX dealer but I'd prefer mail order if possible.
#45 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 18 March 2006 - 02:50 PM
Drive vauxhall in bristol thumbsup not sure whether they mail though :unsure:
#46 Shep
Shep
  • 802 posts
Posted 18 March 2006 - 05:48 PM
Yeah local VX dealer.
#47 djegiant
djegiant
  • 2,367 posts
Posted 18 March 2006 - 09:21 PM
Page 223 in 2005 demon tweeks road catalogue. Cant find it on the web anywhere but it looks B) Made by spec-r with sight glass! For bling merchants only! :lol: Edit; sorry chris but I dont think they do a black one! :P
Edited by djegiant, 18 March 2006 - 09:22 PM.
#48 christurbo
christurbo
  • 3,784 posts
Posted 18 March 2006 - 09:24 PM
Ha :P :lol: I know which one you mean - hard to tell how much coolant is left in your system though??
Edited by christurbo, 18 March 2006 - 09:24 PM.
#49 djegiant
djegiant
  • 2,367 posts
Posted 18 March 2006 - 09:25 PM
Has a clear tube on the side so you can see the level! thumbsup
#50 jules_s
jules_s
  • 15,275 posts
Posted 18 March 2006 - 09:36 PM
as an extra though yeah?
#51 covert ops
covert ops
  • 1,265 posts
Posted 19 March 2006 - 10:02 AM
for bling merchants only! :lol:
I have the one without the guage. :(
However no more UV failures once thats fitted ;)
thumbsup
Bling Bling
Andy chinky chinky
#52 Joe-Turbo
Joe-Turbo
  • 4,176 posts
Posted 19 March 2006 - 08:45 PM
has any one got the part number for this?
#53 Jase_MK
Jase_MK
  • 6,277 posts
Posted 20 March 2006 - 09:11 AM
Just ring up your dealer and tell them you want a coolant expansion tank/header tank.
Replaced mine about 3 weeks ago for about £17. The coolant used to need topping upi every 2 or 3 weeks, seems OK now thumbsup
#54 kwacker636
kwacker636
  • 90 posts
Posted 12 August 2006 - 03:24 PM
:blink: :unsure: Well today, I fitted my gearbox breather pipe & filter, ready for the National meet & Tracking around Snetterton, And thought I'd take a long drive rallly Coolant temp was between 84-92 O'c not too bad then saw the coolant warning light (I had mentioned this to Drive Bristol about 4wks ago when it was in but they found nothing), pulled in to next services only to find a lack of coolant & minute bubbles on the top by the return pipe, looks like mine gone :o - replacement time. Q - Are these being replaced under warranty? (03 Vxt) Q - no solution from Vauxhall ? (I've sen the UV covers on ebay) cheers Ben.
#55 NickH
NickH
  • 2,171 posts
Posted 12 August 2006 - 03:48 PM
A - They have been replaced under warranty but yours has probably run out now, IIRC the tanks are only about £25 from vauxhall and are easy to change so I'd consider doing it yourself, I think somebody posted a guide on how to change them.
A - The only solution is to change the tank to a metal one which can be purchased but not from vauxhall and ofcourse Elaine's covers thumbsup ;) . Alternatively just replace them every couple of years, a fairly consumable item at that price and quite reasonable thumbsup
HTH
Nick thumbsup
Edited by NickH, 12 August 2006 - 03:50 PM.
#56 tede
tede
  • 86 posts
Posted 22 August 2006 - 08:16 PM
My header tank started leaking at the weekend from the top hose. Ordered a new header tank from Vauxhall yesterday which they got in today from the factory. £17 +VAT. Took about 15/20 mins to fit this evening following the instructions earlier in this thread. Thanks for the tips! thumbsup
#57 mja182
mja182
  • 1,129 posts
Posted 23 August 2006 - 08:50 AM
How come none of you guys have fitted a cover to protect the tank from the sunlight?
Only a tenner to buy and looks easy to fit. Prevention rather than cure
http://cgi.ebay.co.u...1QQcmdZViewItem
#58 bigbadben
bigbadben
  • 276 posts
Posted 24 August 2006 - 11:39 AM
Part #: 9117437
Should be £20.80
thumbsup
#59 medlow
medlow
  • 258 posts
Posted 25 August 2006 - 11:54 AM
Ding!!
Ding Ding!!!! Looks like it would explode the next time I got stuck in traffic!! The picture does not show anywhere near as much cracking under the surface. :blink:
30 mins later and I'm patting myself on the back..! Simple job, even for a novice like me!
1: Remove top pipe (squeeze pipe clamp with pliers and slide off).
2: Unclip mounting bracket paperclip thing (small flat head screwdriver and prise off)
3: Remove sensor underneth (simple pulling and twisting)
4: Get some mole grips on the bottom, large pipe clamp and squeeze it open enouth to get the pipe off. (leave molegrips in place ready for filtting the new bottle.!)
5: Quickly remove bottle and stick it in a clean bucket/bowl to catch the antifreeze mix.
6: Fit new bottle in reverse to above.
7: Fill bottle with original antifreeze mix from the bucket/bowl. Top up if needed.
8: Quickly rinse off any spilt antifreeze with water.
Job done.!
James.
#60 Elaine
Elaine
    S4s Esprit.
  • 1,574 posts
  • Interests:Cars, Guns, Keeping fit & healthy eating (Taking note of the Chapman theory).
Posted 25 August 2006 - 02:38 PM
I've got one! :D ;)
Reg has put some more on ebay, or you can get one direct from his website.
Cheers for the plug Nick. :)
E. chinky chinky
Edited by Elaine, 25 August 2006 - 02:39 PM.
