Edited by Tolksee, 29 June 2005 - 11:16 AM.
Monorep, Southall
Started by
Tolksee
, Jun 29 2005 11:14 AM
2 replies to this topic
Posted 29 June 2005 - 11:14 AM
OK so my car went in for:
- Wind noise at >60mph from around Passenger Window frame. Probably linked to:
- Passenger Window not adjusted properly - there was a small gap between window and rubber
- Creak noise below passenger door handle
- Creak noise Driver's side around back of big plastic roof thingy
6 hours later, it's done. "All done", says the man. "Cool", says I.
Get in the car.
- There's small bits of the silver paint chipped off the plastic door handle card at the 2 corners where they have removed it. Ah hell, I suppose they had to do that to remove it.....
- The Window winder is in the wrong position. OK I can fix that - 4 allen bolts, hopefully no biggie.
Drive Home
- Wind noise still present
- Creak still present.
OK, I'll have to live with these.......
Get home. Wind up the window. sh*t! It goes halfway up and refuses to go higher. Back to Monorep. They take the car in and 20 minutes later I have the car back, window able to go up to the top now. (Winder still in wrong position.)
So as far as I can see, they didn't scratch the outside of my car, or introduce any new creaks or rattles. But they chipped bits of silver paint off, only fixed 2 of the 4 things it went in for, AND they've left me with a window winder in the wrong position.
Just a bit dissolusioned with them really.
PS - can someone confirm it's just 4 allen bolts to change the postion of the WIndow winder? Anything I should know before attepting it?
Cheers.
Lee
Posted 29 June 2005 - 11:38 AM
4 allen bolts, then another allen bolt underneath and remove. I bet you'll never be able to get the level perfect though, I#'ve never managed it
Posted 29 June 2005 - 11:43 AM
Thanks for Reply Thorney.
The perfect level's not mega-important - it's that the winder is a quarter-turn in the wrong position.
Edited by Tolksee, 29 June 2005 - 11:45 AM.
