Front Splitter
51 replies to this topic
#1 garyk220
garyk220
  • 3,035 posts
Posted 09 July 2005 - 07:01 PM
I've been looking around for ideas for a front splitter for a while now. The criteria I had in mind were: - about 60mm deep - flexible enough to absorb impacts from kerbs and speed bumps (for when I lower my car) - cheap (ie. replaceable) - readily available - ideally fit without any major modifications The previous model Astra G, looked to have one that was just about ideal. So, I picked one up from my local Vauxhall dealer to try it out. I've not got round to refitting the clam yet - got a few other jobs to sort in the next few weeks - but here's some pics of the splitter mounted on the clam. Literally took 1/2 hour to fit.
Edited by garyk220, 09 July 2005 - 07:02 PM.
#2 garyk220
garyk220
  • 3,035 posts
Posted 09 July 2005 - 07:03 PM
A close up. It comes in 2 sections, is 60mm deep at the sides and 35mm deep at the centre, and cost £30 per side.
#3 garyk220
garyk220
  • 3,035 posts
Posted 09 July 2005 - 07:04 PM
And from the side. The fit is almost millimetre perfect. You'd never believe it was not made for the VX.
#4 garyk220
garyk220
  • 3,035 posts
Posted 09 July 2005 - 07:07 PM
And a close-up of the fittings. I drilled 10 pilot holes in the clam and used screws with fasteners on the inside, and a couple of pop rivets in the existing splitter holes on the outer fittings. It is made out of rubber, so should stand up to minor impacts pretty well. And at £30 a side, no big deal to replace every now and then. Pretty pleased with the results. I don't expect much difference in performance, not at least till I fit Nitrons or Ohlins later in the year, but every little helps.
Edited by garyk220, 09 July 2005 - 07:09 PM.
#5 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 09 July 2005 - 07:14 PM
thumbsup Nice one Gary
#6 Ducati996Senna
Ducati996Senna
  • 815 posts
Posted 09 July 2005 - 09:10 PM
I second that. A great bit of info. thumbsup
#7 ianrm
ianrm
  • 11,097 posts
Posted 09 July 2005 - 09:21 PM
Thirded. Looks the part thumbsup Colour coding ?
#8 2GOOD
2GOOD
    Old Timer zzz...
  • 4,451 posts
Posted 10 July 2005 - 08:34 AM
Colour coding ?
I'd have thought it's to flexible to be painted.
#9 wrightster
wrightster
  • 2,808 posts
Posted 10 July 2005 - 08:40 AM
i like that very ingenious (?) .... its smart :D
#10 Richy
Richy
  • 8,699 posts
Posted 10 July 2005 - 09:47 AM
Looks good mate thumbsup I cant wait to see it, when its all back on B)
#11 Ricky2772
Ricky2772
  • 3,685 posts
  • Interests:For those who grasp for Hir beyond the horizon of usual consciousness, preparing for the time when something powerful will present Hir-Self This advise is given...
Posted 10 July 2005 - 06:57 PM
u are a ferking genius gary.... B) thumbsup astra G...mmmmm ...all of them had it installed or only upscale models?
#12 Scottieb
Scottieb
  • 1,088 posts
Posted 10 July 2005 - 07:52 PM
That looks ace gary... any chance of the part numbers Imnotworthy
#13 garyk220
garyk220
  • 3,035 posts
Posted 10 July 2005 - 09:06 PM
Ricky, all base model Astras have these. Vauxhall part numbers, 90546957 and 90546958.
#14 CocoPops
CocoPops
  • 17,181 posts
Posted 10 July 2005 - 09:09 PM
Proper Job thumbsup Probably find em cheap as well when the astra's make it into the breakers yard ;)
#15 Thorney
Thorney
  • 11,404 posts
    Fluffy bunny rabbits.
Posted 11 July 2005 - 06:48 AM
That is inspired thumbsup Looks a (little) too big without a wing to compensate but the overall shape is broadly similar to the CF I've got. thumbsup
#16 2GOOD
2GOOD
    Old Timer zzz...
  • 4,451 posts
Posted 11 July 2005 - 07:19 AM
Proper Job thumbsup
Astra G's the previous model 98-04 so should have been in the brakers for awhile now thumbsup
#17 barrybethel
barrybethel
  • 1,112 posts
Posted 11 July 2005 - 05:49 PM
Looks good off the car Gary but don't forget the bottom of the clam is not parallel with the road when it's fitted to the car. From the front of the wheelarch it rises, to the front of the car. My airdam is tapered to account for this, which I think works well - the lower edge of the airdam when viewed from the side is parallel with the road. Yours might look OK I dunno. Apart from that though it looks like a brilliant solution. Will you post some pics when the clam is on the car?
#18 vxr36
vxr36
  • 1,179 posts
Posted 12 July 2005 - 08:15 AM
Cool Gary, just ordered mine from Monorep - they are in stock. Picking them up on Friday to play with on Saturday. What fixings did you use? Plasic ones that may give under imact or metal ones? Where did you get them from? Thanks for you ingenuity. Wanted some scrivets too as I am missing 3 but changed my mind..... £5 each :beat:
#19 garyk220
garyk220
  • 3,035 posts
Posted 13 July 2005 - 12:01 PM
Couple of pics of clam refitted.
#20 garyk220
garyk220
  • 3,035 posts
Posted 13 July 2005 - 12:02 PM
And from the side. I hadn't thought about the slope on the clam Dean, but looking at this photo, I think I got away with it.
