Front Splitter
#41
Posted 24 July 2005 - 06:20 PM
#42
Posted 24 July 2005 - 06:22 PM
Edited by vxr36, 24 July 2005 - 06:25 PM.
#43
Posted 24 July 2005 - 06:24 PM
#44
Posted 26 July 2005 - 10:05 AM
#45
Posted 26 July 2005 - 10:33 AM
#46
Posted 26 July 2005 - 10:55 AM
Dave
#47
Posted 26 July 2005 - 11:34 AM
pleased with mine too
Edited by minime, 26 July 2005 - 11:35 AM.
#48
Posted 26 July 2005 - 11:50 AM
#49
Posted 29 July 2005 - 10:34 AM
#50
Posted 29 July 2005 - 10:59 AM
and fittedon order
#51
Posted 01 September 2005 - 10:22 AM
#52
Posted 01 September 2005 - 10:35 AM
I drilled a hole at either end of the cut-outs, drilled a few intermediate holes on the longer ones, and then cut-out the remaining material using a sharp blade. Finished it off with a file, before painting. It looks fine from a distance, but there are one or two rough, and non-circular edges up close, but it does the job.Gary, apologies if it's already been covered but how did you go about venting your V/grill like that? Drill and hacksaw? Looks pretty neat.
I'm assuming this is entirely coincidental, but since refitting the clam and grille, my car has run 2 degrees cooler. Now runs at 84-85 degrees when cruising. I can't see how better airflow through the radiator would result in this alone, since the thermostat should regulate the coolant to a stable temperature. Unless of course, the thermostat is premanently open and more airflow equals cooler temps. Probably coincidental though, and indicating a problem with the thermostat.
PS The rubber splitter has already worked. I broke a number plate and clouted the bottom of my clam after dropping both wheels into potholes approaching a speed bump (not a good combination ). The splitter doesn't have a mark on it. a solid one would have been in pieces.
Edited by garyk220, 01 September 2005 - 10:39 AM.
