The Useful Thread Collection
83 replies to this topic
#21 christurbo
christurbo
  • 3,784 posts
  • Interests:My Civic Type R
    My Black Beast of a VX!!!
Posted 13 January 2006 - 04:46 PM
Water Ingress Kit fixture to a NA:-
Water Ingress Kit Mod
Both Bad Ass Engine covers fitted:-
Bad Ass Engine Covers
Trolley Jack:-
Trolley Jack
Edited by christurbo, 13 January 2006 - 05:05 PM.
#22 Dave
Dave
  • 3,679 posts
Posted 22 January 2006 - 08:46 PM
Image Resizer, never have a life size photo on this site again.
Problems posting photo's the correct size on this site then use this useful tool direct from the Microsoft site.
"Image Resizer
This PowerToy enables you to resize one or many image files with a right-click."
Found by StuXVR
Dave
#23 christurbo
christurbo
  • 3,784 posts
Posted 04 February 2006 - 12:34 PM
Accelerator Sensor Failure???? A fix here:-
ACCELERATOR SENSOR FAILURE FIX
#24 christurbo
christurbo
  • 3,784 posts
Posted 04 February 2006 - 09:22 PM
HARNESS FITTING GUIDE
thumbsup
#25 iceman
iceman
  • 18,159 posts
Posted 09 February 2006 - 05:26 PM
Paint Code List..with DuPont stock codes
#26 JawZ
JawZ
  • 2,571 posts
Posted 16 February 2006 - 03:32 AM
Color / Styling - Image Database
View photos of the VX in any of the standard colors, or have a look at a wide range of styled / custompainted VXs
Edited by JawZ, 16 February 2006 - 03:35 AM.
#27 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 20 February 2006 - 09:26 AM
MPG Calculator
Edited by VXT Tim, 20 February 2006 - 09:27 AM.
#28 jneill
jneill
  • 3,945 posts
  • Interests:QI
Posted 11 March 2006 - 11:38 PM
Owners Manual
That link doesn't seem to work anymore.
>try this<
#29 caleebra
caleebra
  • 4,479 posts
Posted 12 March 2006 - 10:40 PM
The Steering Column Bolts
#30 christurbo
christurbo
  • 3,784 posts
Posted 17 March 2006 - 04:37 PM
Brakes spongy after changing brake fluid?
Bleeding Solution
#31 jneill
jneill
  • 3,945 posts
  • Interests:QI
Posted 18 March 2006 - 09:49 AM
Top Gear: Clarkson video of the VXT
http://homepage.ntlw..._uk/topgear.mpg
#32 Ollie_VXT
Ollie_VXT
  • 492 posts
Posted 23 March 2006 - 11:03 AM
Tyre Suppliers/Fitters & Prices
thumbsup
Edited by Ollie_VXT, 23 March 2006 - 11:03 AM.
#33 christurbo
christurbo
  • 3,784 posts
Posted 11 May 2006 - 06:41 PM
>>>>> JIM'S FULL BRAKE SERVO HOSE REPLACEMENT<<<<<
chinky chinky
Edited by christurbo, 11 May 2006 - 06:42 PM.
#34 jneill
jneill
  • 3,945 posts
  • Interests:QI
Posted 11 May 2006 - 06:44 PM
Link to VX220 wiki
http://vx220.wikispaces.com/
thumbsup
#35 bigbadben
bigbadben
  • 276 posts
Posted 23 August 2006 - 10:09 AM
Rear Tie Bar/ Track Rod End Replacement
Rears can apparently only now be bought as a 'kit' consisting of 1x tie rod and 2x track rod ends (Part #: 93178112).
If you want to tackle this job yourself and fit these parts you apparently need:
- 2x track-rod kit - £56 + VAT (from Vauxhall)
- 4x nylock nuts - £2.37 each + VAT (min. quantity 10 from Vauxhall)
The Nylock nuts are M10 x 1.25 pitch/ 14mm and can be bought individually from GWS Fastenings (01225 767630) @ £1.75 each.
Oh, and they're stainless steel (much better than the quality of the Vx items too!!)
Cheapest place to buy them from is > AutoVaux < at ~£46 inc VAT (normally ~£66 from Vx).
* Bear in mind that you will need a geo setup after installation! (see below)
I tackled this job with a friend and the measurements given in the guide are a bit of a red herring. The guide mentions using the measurement from the moveable shaft (that either attaches to the hub or to the wishbone, depending which end you are concentrating on!) to the adjustment nut. This shaft obviously moves and gives a false/ inaccurate measurement...
The most accurate method (loose interpretation of 'accurate'!) I found was to try and find the centre point of the encased ball joint - using inner lip of the joint to get the diameter, then halving it and scoring 3 lines into the casing - then measuring the distance from this point to the outer edge of the adjustment nut. I used this method for all four TRE's and managed to get home without any adverse affects to the handling. I'm still having the geometry checked by Plans Motorsport for peace of mind!
mod edit: 3 posts consolidated at poster's request
mod edit again: at poster's request!
Edited by Foxy, 02 October 2006 - 01:26 PM.
#36 vx220na
vx220na
  • 684 posts
  • Interests:Cars, leetube.co.uk (making tunes) Gaming, Drums, Art... etc etc
Posted 28 September 2006 - 10:38 PM
Rear wheel driving tips......
Tips are here.
#37 NOBLE
NOBLE
  • 2,316 posts
Posted 09 October 2006 - 12:01 PM
Noble's guide for removing the front V
#38 jimbob
jimbob
  • 798 posts
Posted 11 October 2006 - 08:15 PM
VX220 TURBO BUYERS CHECKLIST (scroll down)
VXT Buyers Checklist
#39 NOBLE
NOBLE
  • 2,316 posts
Posted 16 October 2006 - 02:04 PM
Noble's guide to fitting a front Leon Spoiler
#40 stormtrooper
stormtrooper
  • 165 posts
Posted 29 October 2006 - 11:24 PM
Door panel / Door cards & Window winder removal thumbsup
