The Useful Thread Collection
83 replies to this topic
#61 framauro
framauro
  • 1,960 posts
Posted 16 February 2008 - 10:19 PM
All current listed VOSA recalls for the VX220.
fyi - list is valid until the year 2100! :D
#62 walshy123
walshy123
  • 46 posts
Posted 18 August 2008 - 10:37 AM
Regaining heater speeds 1 & 2
http://www.vx220.org...showtopic=42236
Edited by walshy123, 18 August 2008 - 10:37 AM.
#63 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 31 August 2008 - 10:03 PM
Fitting a new steering rack :)
#64 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 08 October 2008 - 02:02 PM
GM Customer Care and Recalls numbers
#65 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 29 October 2008 - 09:12 AM
Bilstein Technical Centre contact details
For damper reconditioning or spare parts.
#66 mandarinvx
mandarinvx
  • 12,621 posts
Posted 01 February 2009 - 10:54 AM
A list of all bulb types thumbsup
#67 blangs
blangs
  • 81 posts
Posted 14 March 2009 - 10:54 PM
Seat Removal - Numpty Edition thumbsup
Edited by blangs, 14 March 2009 - 10:55 PM.
#68 mandarinvx
mandarinvx
  • 12,621 posts
Posted 11 April 2009 - 10:18 AM
Uprated Anti Roll Bar installation guide :)
#69 Shmern
Shmern
  • 141 posts
Posted 02 May 2009 - 02:09 PM
ABS off switch fitting guide
http://www.vx220.org...off-switch.html
It's in the Blogs so doesn't come up in searches ! (I know cos I've been searching for a while until some kind soul pointed me in the right direction :) )
Shmern
#70 mandarinvx
mandarinvx
  • 12,621 posts
Posted 04 October 2009 - 09:28 PM
Spitfire Toe Link Fitting Pictures :)
#71 craggers
craggers
  • 221 posts
Posted 27 February 2010 - 12:39 PM
when i click the links on the first page for eg. rear pad replacement... it just takes me back to the opening forum page... :(
#72 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 03 March 2010 - 03:19 PM
New part numbers
part numbers
#73 Art
Art
  • 145 posts
Posted 03 March 2010 - 04:11 PM
Since it's a slow day at work, I thought I'd see if I can fix the links to the threads that are missing as the issue seems to be around how the forum now writes the URL.
These now work, and please note, I don't work for the guys who run the site, just bored at work!
Rear Pad Replacement
Front Pad Replacement
Potenza Codes etc 1
Potenza Codes etc 2
Jacking/Precat Removal
Precat
Viper Fitting, Precat Removal
Viper Fitting
Headlamp Unit Repair
Window Adjustment/Leaks
List of VX220 product integrity issues / recalls / improvments, etc
Adjusting the sensitivity of the microwave (cabin) alarm
Coolant expansion bottle failure, and replacement advice
The sock modification...advice on how to stop the bugs entering your cabin through the air vents....
NA Gearbox Oil change. Step by step guide
Rear Brake Caliper Service Kit, Service
Get More Heat From The Heater 1
Get More Heat From The Heater 2
New Contact At Bridgstones
Dash Removal
Jacking Points
Window Adjustment Guide
Water Ingress Kit Mod for NA
Bad Ass Engine Covers
ACCELERATOR SENSOR FAILURE FIX
Harness Fitting Guide
Paint Code List..with DuPont stock codes
The Steering Column Bolts
Brakes spongy after changing brake fluid - Bleeding Solution
Tyre Suppliers/Fitters & Prices
JIM'S FULL BRAKE SERVO HOSE REPLACEMENT
Rear Tie Bar/ Track Rod End Replacement
steve crisps anti rattle door pin fitting guide
#74 craggers
craggers
  • 221 posts
Posted 03 March 2010 - 09:29 PM
Cor blimey! very bored.. you must have been! but very much appreciated! thank you! :D
#75 NickB787
NickB787
  • 7,813 posts
Posted 10 March 2010 - 08:48 AM
COOLANT SENSOR. Usually located on the cylinder head or intake manifold, this sensor is used to monitor the temperature of the engine’s coolant. Its resistance changes in proportion to coolant temperature. Input from the coolant sensor tells the computer when the engine is warm so the PCM can go into closed loop feedback fuel control and handle other emission functions (EGR, canister purge, etc.) that may be temperature dependent. Coolant Sensor Strategies: The coolant sensor is a pretty reliable sensor, but if it fails it can prevent the engine control system from going into closed loop. This will result in a rich fuel mixture, excessive fuel consumption and elevated carbon monoxide (CO) emissions - which may cause the vehicle to fail an emissions test. A bad sensor can be diagnosed by measuring its resistance and watching for a change as the engine warms up. No change, or an open or closed reading would indicate a bad sensor. OXYGEN (O2) SENSOR. Used on both carbureted and fuel injected engines since 1981, the oxygen (O2) sensor is the key sensor in the fuel mixture feedback control loop. Mounted in the exhaust manifold, the O2 sensor monitors the amount of unburned oxygen in the exhaust. On many V6 and V8 engines, there are two such sensors (one for each bank of cylinders). The O2 sensor generates a voltage signal that is proportional to the amount of unburned oxygen in the exhaust. When the fuel mixture is rich, most of the oxygen is consumed during combustion so there is little unburned oxygen in the exhaust. The difference in oxygen levels between the exhaust inside the manifold and the air outside creates an electrical potential across the sensor’s platinum and zirconium tip. This causes the sensor to generate a voltage signal. The sensor’s output is high (up to 0.9v) when the fuel mixture is rich (low oxygen), and low (down to 0.1v) when the mixture is lean (high oxygen). The sensor’s output is monitored by the computer and is used to rebalance the fuel mixture for lowest emissions. When the sensor reads "lean" the PCM increases the on-time of the injectors to make the fuel mixture go rich. Conversely, when the sensor reads "rich" the PCM shortens the on-time of the injectors to make the fuel mixture go lean. This causes a rapid back-and-forth switching from rich to lean and back again as the engine is running. These even waves result in an "average" mixture that is almost perfectly balanced for clean combustion. The switching rate is slowest in older feedback carburetors, faster is throttle body injection systems and fastest in multiport sequential fuel injection. If the O2 sensor’s output is monitored on an oscilloscope, it will produce a zigzagging line that dances back and forth from rich to lean. Take a look at the waveform on the opposite page - that’s what a technician wants to see when he checks the O2 - think of it as a kind of heart monitor for the engine’s air/fuel mixture. O2 Sensor Strategies: Unheated one- or two-wire O2 sensors on 1976 through early 1990s applications should be replaced every 30,000 to 50,000 miles to assure reliable performance. Heated 3 and 4-wire O2 sensors on mid-1980s through mid-1990s applications should be changed every 60,000 miles. On OBD II equipped vehicles, the recommended replacement interval is 100,000 miles. The O2 sensor’s responsiveness and voltage output can diminish with age and exposure to certain contaminants in the exhaust such as lead, sulfur, silicone (coolant leaks) and phosphorus (oil burning). If the sensor becomes contaminated, it may not respond very quickly to changes in the air/fuel mixture causing a lag in the PCM’s ability to control the air/fuel mixture. The sensor’s voltage output may decline giving a lower than normal reading. This may cause the PCM to react as if the fuel mixture were leaner than it really is resulting in an overly rich fuel mixture. How common is this problem? One EPA study found that 70 percent of the vehicles that failed an I/M 240 emissions test needed a new O2 sensor. MANIFOLD ABSOLUTE PRESSURE (MAP) SENSOR. This sensor is mounted on or connected to the intake manifold to monitor intake vacuum. It changes voltage or frequency as manifold pressure changes. The computer uses this information to measure engine load so ignition timing can be advanced and retarded as needed. It performs essentially the same job as the vacuum advance diaphragm on an old fashioned mechanical distributor. On engines with a "speed density" type of fuel injection, the MAP sensor also helps the PCM estimate airflow. Problems here may cause an intermittent check engine light (light comes on when accelerating or when the engine is under load), hesitation when accelerating, elevated emissions and poor engine performance. The engine will run with a bad MAP sensor, but it will run poorly. Some PCMs can substitute "estimated data" for a missing or out of range MAP signal, but engine performance will be drastically reduced. MAP Sensor Strategies: Some MAP sensor problems are not the fault of the sensor itself. If the vacuum hose that connects the MAP sensor to the intake manifold is loose, leaking or plugged, the sensor can’t produce an accurate signal. Also, if there is a problem within the engine itself that causes intake vacuum to be lower than normal (such as a vacuum leak, EGR valve that’s stuck open or leaky PCV hose), the MAP sensor’s readings may be lower than normal. THROTTLE POSITION SENSOR. Mounted on the throttle shaft of the carburetor or throttle body, the throttle position sensor (TPS) changes resistance as the throttle opens and closes. The computer uses this information to monitor engine load, acceleration, deceleration and when the engine is at idle or wide open throttle. The sensor’s signal is used by the PCM to enrich the fuel mixture during acceleration, and to retard and advance ignition timing. Throttle Position Sensor Strategies: Many TPS sensors require an initial voltage adjustment when installed. This adjustment is critical for accurate operation. On some engines, a separate idle switch and/or wide open throttle (WOT) switch may also be used. Driveability symptoms due to a bad TPS can be similar to those caused by a bad MAP sensor: The engine will run without this input, but it will run poorly. MASS AIRFLOW SENSOR (MAF). Mounted ahead of the throttle body on multiport fuel injected engines, this sensor monitors the volume of air entering the engine. The sensor uses either a hot wire or heated filament to measure both airflow and air density. MAF Sensor Strategies: The sensing element in MAF sensors can be easily contaminated causing hard starting, rough idle, hesitation and stalling problems. VANE AIRFLOW SENSOR (VAF). The VAF has a mechanical flap-style sensor that is used on Bosch and other import multiport fuel injected engines. The function is the same as a mass airflow sensor, but air pushing against a spring-loaded flap moves a rheostat to generate an electronic signal. VAF Sensor Strategies: The drivability symptoms for the VAF are the same as those of a mass airflow sensor if the sensor fails. MANIFOLD AIR TEMPERATURE (MAT) SENSOR. Mounted on the intake manifold, this sensor changes resistance to monitor incoming air temperature. The sensor’s input is used to adjust the fuel mixture for changes in air density. MAT Sensor Strategies: Problems with the manifold air temp sensor can affect the air/fuel mixture, causing the engine to run rich or lean. CRANKSHAFT POSITION SENSOR. Used on engines with distributorless ignition systems, the crankshaft position sensor serves essentially the same purpose as the ignition pickup and trigger wheel in an electronic distributor. It generates a signal that the PCM needs to determine the position of the crankshaft and the number-one cylinder. This information is necessary to control ignition timing and the operation of the fuel injectors. The signal from the crank sensor also tells the PCM how fast the engine is running (engine rpm) so ignition timing can be advanced or retarded as needed. On some engines, a separate camshaft position sensor is also used to help the PCM determine the correct firing order. The engine will not run without this sensor’s input. There are two basic types of crankshaft position sensors: magnetic and Hall effect. The magnetic type uses a magnet to sense notches in the crankshaft or harmonic balancer. As the notch passes underneath, it causes a change in the magnetic field that produces an alternating current signal. The frequency of the signal gives the PCM the information it needs to control timing. The Hall effect type of crank sensor uses notches or shutter blades on the crank, cam gear or balancer to disrupt a magnetic field in the Hall effect sensor window. This causes the sensor to switch on and off, producing a digital signal that the PCM reads to determine crank position and speed. Crank Position Sensor Strategies: If a crank position sensor fails, the engine will die. The engine may, however, still crank but it won’t start. Most problems can be traced to faults in the sensor’s wiring harness. A disruption of the sensor supply voltage (Hall effect types), ground or return circuits can cause a loss of the all-important timing signal. KNOCK SENSOR. The knock sensor detects engine vibrations that indicate detonation is occurring so the computer can momentarily retard timing. Some engines have two knock sensors. Knock Sensor Strategies: A failure with the knock sensor can cause spark knock and engine damaging detonation because the PCM won’t know to retard ignition timing if knock is occurring. BAROMETRIC PRESSURE (BARO) SENSOR. The baro sensor measures barometric pressure so the computer can compensate for changes in altitude and/or barometric pressure that would affect the fuel mixture or timing. Some MAP sensors also perform this function. VEHICLE SPEED SENSOR (VSS). The vehicle speed sensor, or VSS, monitors vehicle speed so the computer can regulate torque converter clutch lockup, shifting, etc. The sensor may be located on the transmission, differential, transaxle or speedometer head. Vehicle Speed Sensor Strategies: A problem with the vehicle speed sensor can disable the cruise-control system as well as affect transmission shifting and converter engagement. Replacing a sensor won’t solve a drivability or emissions problem if the problem isn’t the sensor. Common conditions such as fouled spark plugs, bad plug wires, a weak ignition coil, a leaky EGR valve, vacuum leaks, low compression, dirty injectors, low fuel pressure or even low charging voltage can all cause driveability symptoms that may be blamed on a bad sensor. If there’s are no sensor-specific fault codes, these kinds of possibilities should be ruled out before much time is spent on electronic diagnosis.
#76 old codger
old codger
  • 462 posts
  • Interests:Clay pigeon shooting, motor racing, cars and bikes.
Posted 20 March 2010 - 05:23 PM
I am being taken back to the home page when I try to open the useful thread selection. Something strange here. thumbsdown
#77 jneill
jneill
  • 3,945 posts
  • Interests:QI
Posted 10 May 2010 - 10:04 AM
A glaring omission: The VX220 Owner's Thesaurus Posted Image
Edited by jneill, 10 May 2010 - 10:04 AM.
#78 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 13 August 2010 - 11:58 AM
http://vx220.wikispaces.com/Paint
New link as the old one is foobed.
#79 SteveA
SteveA
  • 9,159 posts
Posted 17 August 2011 - 09:11 AM
Vinyl Wrapping a windscreen surround
CLICK
#80 smiley
Posted 08 September 2011 - 01:17 PM
VX220 statstics. How many made, lost etc. http://www.vx220.org...106561-vx-stats
