Mine had this, Thorney sorted it when i had the stage 2 work done a couple of weeks ago. Think the switch was around £12 but not certain, wasn't too expensive!
Help - No Reverse Light
Started by
TonyKL
, Sep 17 2005 09:14 AM
26 replies to this topic
#21
Posted 13 December 2005 - 12:05 PM
#22
Posted 03 May 2011 - 10:19 AM
This is another great reason, why this site is the best for hints and tips!!
removed the switch from the gear box, some WD40..........bingo working again.......
BUT what a silly place to put a switch!!
Thanks Vx220.org
#23
Posted 03 May 2011 - 12:44 PM
some WD40..........bingo working again.......Thanks Vx220.org
And thanks to WD40 by the sound of things. That stuff works magic sometimes.
#24
Posted 03 May 2011 - 01:24 PM
Had my switch changed today when I changed the oil and filter. The switch is only a few quid but you may find the labour from them having to remove the undertray is the most expensive bit. Changing the switch shouldn't take long.
#25
Posted 03 May 2011 - 03:18 PM
only had to remove the rear pax wheel, then unclip cable, then 19" spanner, removed, cleaned, re fitted, tested, sorted.
#26
Posted 03 May 2011 - 05:59 PM
Its on the side of the gearbox above and behind the N.S drive shaft.
Remove and spray with WD40... A common fault of the switch sticking...
#27 Guest_Minno (Guest)
Posted 03 May 2011 - 09:51 PM
You forgot to say the wheel arch liner had to be removed as well!
I can't see how anyone could reach down from the top and undo it like others have mentioned in different posts.
