Fill Up The Coolingsystem With Water
Posted 19 September 2005 - 09:21 PM
Posted 19 September 2005 - 09:49 PM
Is it just to fill up in the water resovoir, until its full?
Or do you have to bleed the system somehow?
Are you doing a complete flush? If so its usually fill, bleed, start, run to running temp, topup....watch'n for the pressure..... and run and check again..
For normal topup from what I can remember fill the reservoir to about the half level point, that what I do on my NA. I always add a little anti-freeze to the mix
Edited by speedster, 19 September 2005 - 09:52 PM.
Posted 20 September 2005 - 04:51 AM
Posted 20 September 2005 - 07:26 AM
Posted 20 September 2005 - 08:05 AM
just fill her up and start the engine.shall I fill up, open the bleeders , fill some more until it comes water out of the bleeders, close the bleeders and start the engine.. and do it one more time..
does that sound good?
top up as the coolant gets into the system.
when the heat starts to rise you can begin to bleed the air that´s in the system.
Posted 20 September 2005 - 10:48 AM
Posted 20 September 2005 - 11:28 AM
Posted 20 September 2005 - 12:08 PM
Posted 21 September 2005 - 10:44 AM
Afore mentioned supply said ethyl-glycol (Antifreeze) is clear the coolant is made in different colours to try to get you to buy theirs at an extortionate mark up. We where going to us Norfolk Mustard YellowI'm with RWinstanley on this one.
I have been told never to put just water in the cooling system as it corrodes/furs up the insides, just think of a kettle.
My VX was losing coolant a little while ago from a cracked rad pipe. Vauxhall use a brown coloured longlife coolant. Someone on this site made the valid point of not topping up with the blue stuff you seem to be able to buy everywhere. As it is likey to change the properties of the coolant already in there.
However if you are flushing the system and refilling most shops will sell premixed coolant so no dilution with de-ionised water is necessary.
The Long-life part is the OATS and should only need changing every 5 or more years.
Edited by RWinstanley, 21 September 2005 - 10:46 AM.
Posted 24 September 2005 - 10:54 PM
Posted 27 September 2005 - 10:30 AM
Posted 27 September 2005 - 11:06 AM
- you mean Polar bears.antifreeze is obvious, so we left it out in the diskussion
we live in the country where icebears are walking on the streets![]()
So that's what smashed your front clam then
-David.
Posted 27 September 2005 - 02:23 PM
no!- you mean Polar bears.antifreeze is obvious, so we left it out in the diskussion
ÂÂ
we live in the country where icebears are walking on the streetsÂÂ
-David.
that was a bigfoot badger with an attitude
