Edited by chuno, 03 October 2005 - 05:17 PM.
Tyres
Posted 03 October 2005 - 05:11 PM
Posted 03 October 2005 - 05:24 PM
That is the load rating.what is the 91/90 for, does it really matter.
90 = 600kg load capability
91 = 615kg load capability
My N/A has 90W. Maybe for heavy@rsed VXTs the 91 are better, but it sounds like you haven't got the VX specific tyre...
>tyre sidewalls explained<
Posted 03 October 2005 - 05:46 PM
Posted 04 October 2005 - 06:55 AM
Posted 04 October 2005 - 08:32 AM
Posted 04 October 2005 - 09:51 AM
Thanks for thatChuno
I just had exactly the same thing. Couldn't remember the exact dot code & found out afterwards I had the wrong one. & phoned Bridgstone Technical.
The loading rating in itself isn't really the problem.
The dot code is supposedly.... " a unique tyre compound designed specifically for the handling characteristics of the vx" & there's unique one's for the lizzie & Scooby , TT etc
Is there a massive diffference - probably not. But I got mine changed to the correct dot code. The wrong dot code on my 91 tyre was CLB & was for a vw.
If it was a cheap deal & you knew what you were getting then no problem.
If you thought you were getting the correct tyre - then get it changed. IMHO
They cost enough afterall.
The DOT code appears to be correct - CFE, its just the load rating.
They werent that cheap really - £105 each, i was expecting to get the correct ones
Posted 04 October 2005 - 12:20 PM
Posted 04 October 2005 - 12:32 PM
Thanks for that,If it helps, & you want to put your mind to rest.
Speak to Ian 01926 488580 - Bridgstone Technical Dept. - very helpful.
FWIW I think you're ok.
Just phoned them, and they dont appear to be the vauxhall specific tyre - looks like i'll be getting them to change them
Posted 04 October 2005 - 04:41 PM
after my gav a while ago, i was absolutely sure!! i had the wrong tyres fitted (apparently not! though)..So i rang the number/person posted in the 'usefull threads' section. The very nice lady there informed me that the person we have down as our contact has now moved to another department..If it helps, & you want to put your mind to rest.
The new name/number/contact at Bridgestone tyres for us is:
Tom Wheatley..on..01926 488 579
(not my place to add it to the 'useful thread' section but if a mod deems it as important enough, perhaps it may be an idea)
Posted 04 October 2005 - 05:02 PM
The useful thread collection is free for anyone to post in(not my place to add it to the 'useful thread' section but if a mod deems it as important enough, perhaps it may be an idea)
Posted 04 October 2005 - 05:06 PM
Posted 04 October 2005 - 05:08 PM
Rubbish!!!but i tend to try to stay clear of the important stuff i'll only end-up messing it up again
Go forth oh ye cold one...
Posted 04 October 2005 - 05:15 PM
Posted 05 October 2005 - 05:09 PM
Posted 09 October 2006 - 09:44 PM
Posted 09 October 2006 - 09:52 PM
Why did you feel the need to bump this thread?
because I can ??
no really, must of found it in a search and didn't notice the date !
Posted 09 October 2006 - 10:05 PM
because I can ??
TBH I dont think the fronts have ever changed DOT wise.
The rear load/speed rating on the rears changed when the turbo came in....no problem having a higher speed rating
TBH all this DOT code stuff is a crock of shite IMO
Ive had all the DOT variants on mine, and never noticed any difference whatsoever....sure they may be *slightly* different on track at the very limit. But on the road sub 70mph?
FWIW ive got the bridgie 050's on mine now (fitted by TMS)
No difference once again for road use
