Project Jg
1783 replies to this topic
#181 JG
JG
  • 13,612 posts
Posted 22 October 2011 - 04:40 PM
no, all the clues i can think of would make it much too easy. :P
#182 JG
JG
  • 13,612 posts
Posted 22 October 2011 - 04:41 PM
the two crosses should help though, it you know your vx bits. ;) theres a clue for you.
#183 The Batman
Posted 22 October 2011 - 04:43 PM
i give up :lol: whatever it is i dont think its needed :lol:
#184 VX-GT
VX-GT
    me-thin-king
  • 1,031 posts
ecu mounting
#185 JG
JG
  • 13,612 posts
Posted 22 October 2011 - 04:44 PM
well done Mr Atom. thumbsup
#186 The Batman
Posted 22 October 2011 - 04:45 PM
ecu mounting
yeah that was the only thing i could think off, but then i would have thought jg would have put all 4 bolts in i only see 2 x's
ooohh it is so then he can use the air box mount rivnuts?
#187 JG
JG
  • 13,612 posts
Posted 22 October 2011 - 04:46 PM
correct. Uses the air box riv nuts. and i took the picture before the other two holes were measured for.
#188 JG
JG
  • 13,612 posts
Posted 22 October 2011 - 06:07 PM
Here you go (blackberry doesn't like low light very much)
Needs a bit of fiddling with tomorrow, such as some nice spacers between the ecu and plate.
#189 The Batman
Posted 22 October 2011 - 06:10 PM
nice job thumbsup
#190 JG
JG
  • 13,612 posts
Posted 22 October 2011 - 06:15 PM
here you go
Tomorrow's task: clean the ECU :rolleyes:
#191 JG
JG
  • 13,612 posts
Posted 23 October 2011 - 12:29 PM
et voila:
#192 JG
JG
  • 13,612 posts
Posted 23 October 2011 - 12:56 PM
and done (apart from little spacers for mounting the ecu properly.
#193 JG
JG
  • 13,612 posts
Posted 23 October 2011 - 09:01 PM
you know you've hit more than half way when the ratchet finds itself more on the clockwise than anti-clockwaise setting. Front clam is all back on, as is bonnet. thumbsup
#194 siztenboots
  • 26,613 posts
Posted 24 October 2011 - 08:18 AM
I thought it was a SC belt / fuel lines armour
#195 JG
JG
  • 13,612 posts
Posted 24 October 2011 - 08:57 AM
nope, but i'm making one of those too. :rolleyes:
#196 OneYet
OneYet
  • 1,354 posts
Posted 24 October 2011 - 09:05 AM
Extremly nice. But how do you attach the alu to the firewall? Please put a lot of pics up of the belt shield/armour as well. Imnotworthy Imnotworthy
#197 Arno
Arno
  • 1,238 posts
Posted 24 October 2011 - 09:07 AM
Just in case..
Make sure you run a good ground cable to the ECU case or one of the bolts holding it onto the bracket. the Z22SE version grounds via the casing, not via any of the pins in the connectors.
#198 JG
JG
  • 13,612 posts
Posted 24 October 2011 - 09:08 AM
Extremly nice.
Via the old air box mounting bolts. :)
#199 JG
JG
  • 13,612 posts
Posted 24 October 2011 - 09:09 AM
Just in case..
thumbsup
#200 CocoPops
CocoPops
  • 17,181 posts
Posted 24 October 2011 - 09:17 AM
nope, but i'm making one two of those too. :rolleyes:
EFA
kthnxbai
