Project Jg
1783 replies to this topic
#501 CocoPops
CocoPops
  • 17,182 posts
Posted 07 April 2012 - 01:24 PM
Plug it in... I'll be round to razz your car from 0-60 shortly :)
#502 techieboy
Posted 07 April 2012 - 01:26 PM
Chav.
Oh, wait a minute....
#503 JG
JG
  • 13,612 posts
Posted 07 April 2012 - 01:28 PM
Ah, thats exactly where i was going to put it. Going to use that dash of yours i've had for about three years. Is there a big enough hole behind the dash there? It came with the additional GPS Ariel as a freebee, so guess you have that mounted at the front somewhere.
#504 techieboy
Posted 07 April 2012 - 01:36 PM
There's a cut-out in the aluminium panel behind which needs opening up a bit to suit but nothing a hacksaw blade couldn't handle. My external GPS antenna just pops up from beneath the dashboard cover about midships at the base of the windscreen. Always seems to have decent satellite coverage there as it can "look" straight up to the sky through the screen. Dash cover is currently out of the car and I'm toying with trimming a recess out of the underside for it to sit in and be totally invisible. Reckon it'll happily pick up a GPS signal through a couple of mm's of foam (based on how deeply the satnav antennae in the Audi is buried inside the dash). The theory was when I wasn't using the box, I'd remove it and swap the unmolested dash panel back in to cover the hole but I've never removed it since it went in. :rolleyes:
#505 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 07 April 2012 - 08:44 PM
Right, what does it do? :lol:
Right;
Go make sure you're running the latest firmware
http://www.performan...dlfirmware.html
Then download Circuit Tools
http://www.performan...dlsoftware.html
Then start playing :)
#506 JG
JG
  • 13,612 posts
Posted 07 April 2012 - 08:49 PM
thanks jimmy.
#507 JG
JG
  • 13,612 posts
Posted 08 April 2012 - 06:22 PM
© Mr Simba :D (getting away this afternoon from the inlaws to rubber trim the tat, wasn't sure at first, but i think it works thumbsup)
I'm usually pretty good at avoiding the reflections, not today:
Hiding behind the door:
Not hiding very well
Hiding in the exhaust
#508 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 08 April 2012 - 06:29 PM
What did you use for that? Looks good and would help with the paint chips you collect over time.
#509 MrSimba
MrSimba
  • 5,197 posts
Posted 08 April 2012 - 06:39 PM
That trim just looks soooooooo much better! Car looks amazing as usual as well! :)
#510 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Sooooo clean and shiney :wub: /off to post some pics of mine to balance the clean/shitty content
#511 JG
JG
  • 13,612 posts
Posted 08 April 2012 - 06:41 PM
The funny thing is its absolutely filthy. Just isn't coming up in the pics.
#512 JG
JG
  • 13,612 posts
Posted 08 April 2012 - 06:59 PM
i merely copied you. :)
#513 MrSimba
MrSimba
  • 5,197 posts
Posted 08 April 2012 - 07:10 PM
And i copied Mani & Giles!!!! ;)
#514 JG
JG
  • 13,612 posts
Posted 08 April 2012 - 07:11 PM
to be honest i just wanted an excuse to get out of the house :lol:
#515 techieboy
Posted 08 April 2012 - 07:14 PM
Beat you all then. Did mine about 4 years ago but it was just another thing that started to p!ss me off when removing/refitting the diffuser, so it went the same way as some of the other fittings that came with it. :beat:
#516 JG
JG
  • 13,612 posts
Posted 08 April 2012 - 07:59 PM
:D thats about right, i'm about 4 years behind everyone else :)
#517 The Batman
tubby vents soon ;)
#518 JG
JG
  • 13,612 posts
Posted 08 April 2012 - 08:10 PM
given what i paid for the new na grills i suggest it will be some time :dry:
#519 JG
JG
  • 13,612 posts
Posted 27 April 2012 - 01:45 PM
Abingdon MSE track day today. Good to see Martin, Lauren and Mark.
First outing for the car since supercharging, new brakes, and host of other things. Unsurprisingly it flagged a couple of issues. The least important seems that its quite easy to cook ds2500 brakes (not really a surprise)., even though they are fantastic up to then
The second sounds like it may need slightly more thought and larger intervention.
Third gear, approaching the fastest, left hand corner of the track around 5.5k rpm, maybe 6k, i got what felt like a misfire, which would then pick up again as the corner opened up.
Tank had at least 17L (real - not on the guage), so it wasn't exactly near empty. There was also a pretty nasty smell in the car which definitely smelled engine related. It was so strong i even wondered if something wasn't on fire (which it wasn't) but it was pretty acrid and smelled of hydrocarbons.
Finally, i also have a P1171 lean code.
I've heard and 5OC confirmed, that the symptoms of valve resonance on supercharged cars can be similar to what i've described above.
Any views?
#520 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,353 posts
Posted 27 April 2012 - 01:52 PM
Was it the polish burning off the manifold? On a serious note, I hope you find an easy solution.
    Bing (1)
