Project Jg
#101
Posted 08 May 2011 - 01:22 PM
#102
Posted 08 May 2011 - 01:46 PM
#103
Posted 08 May 2011 - 02:06 PM
Interesting...
2 different (brands?) of rear hubs used? One seems like an OEM (SKF) one with the thick centering flange for the wheel, the other seems like it has a much thinner wall like the 4-bolt versions have..
The axle stub seems to extend a lot further on one, but I guess the pictures were taken when these weren't torqued up yet (don't see a split-pin through the castle-nuts either).
Oh.. I'm not familiar with these toe links so it may be different on these..
But on my Elise if you have the straight M10 bolt type (not the tapered M12 like the VXT and late N/A's) on the outer/upright side then the tapered spacer is usually mounted the other way around. The 'thick' end should then fit (with perhaps a little fettling) inside the recess of the upright.
Again.. Perhaps this kit works differently but I fitted a few from various manufacturers to Elises and VX'es and they all seem to use the same construction.
Edited by Arno, 08 May 2011 - 02:13 PM.
#104
Posted 08 May 2011 - 02:50 PM
#105
Posted 08 May 2011 - 02:57 PM
i used standard shocks for the 'locking in' of the new std bushes.
Can you explain this a bit more to me please
#106
Posted 08 May 2011 - 03:32 PM
#107
Posted 08 May 2011 - 03:39 PM
Cheers Chris, makes sense.Tim,
IIRC JG wants a standard ride height so instead of using the nitrons which hadnt been set up he used standard shocks.
In terms of 'locking in' the bushes when tightening it is advised to do it with the wishbones at the level they would be when the car is sat on its wheels. The theory behind it is that if they are torqued with the wishbones drooping then the when lowered back to the ground the bushes will be twisted.
#108
Posted 08 May 2011 - 04:28 PM
#109
Posted 08 May 2011 - 05:32 PM
I can see what you mean with the toe link, but the spacer is amberglass shape which is why you think it looks like a taper since half of it is in the recess of the upright.
Ah.. That's different then in this kit
Looks nice and clean.. For now.. Look again after you used it for a few weeks
#110
Posted 08 May 2011 - 06:05 PM
Arno.....
It'll be the same in a few weeks..... he doesn't use it!
#111
Posted 14 May 2011 - 07:01 PM
Passed - No advisories.
It was quite nice to hear the MoT man say it was better than new that it was nice to see something done with so much pride and care
Just rolled it into the garage to take it all apart again
#112
Posted 14 May 2011 - 07:04 PM
#113
Posted 15 May 2011 - 09:03 AM
#114
Posted 20 May 2011 - 08:36 PM
#115
Posted 20 May 2011 - 08:37 PM
#116
Posted 20 May 2011 - 08:39 PM
#117
Posted 20 May 2011 - 08:40 PM
#118
Posted 20 May 2011 - 08:50 PM
#119
Posted 17 June 2011 - 01:02 PM
#120
Posted 30 August 2011 - 10:50 PM
