Project Jg
#1261
Posted 06 April 2013 - 09:18 PM
#1262
Posted 06 April 2013 - 09:27 PM
#1263
Posted 06 April 2013 - 09:34 PM
#1264
Posted 06 April 2013 - 09:39 PM
#1265
Posted 07 April 2013 - 09:57 AM
LikewiseGreat to meet you today and look forward to catching up at the National.
#1266
Posted 07 April 2013 - 01:30 PM
may change the rubber fixing at the end of the rail, but its all worked out rather well
ITG is also in
and fits neatly above the fuel filter:
(there is a little spacer to make the filter bracket straight missing in that picture)
Now then, I'm finding that the 2.5Milltek U-bend is a struggle (actually its a bit more than that) to marry up with the tullet. There are two problems. the mating surfaces of the U-bend to Cat section seem to be at 15 degrees to one another, but also, the bolt holes seem to be out buy a rotation of about 20 degrees. Could Milltek (Tullet is fine, since that fitted fine the the oem u-bend) have miss placed the end plate in manufacturing? to make it fit nicely i think i'm going to have to cut it off and re-weld.
#1267
Posted 07 April 2013 - 02:18 PM
The tullet u-bend for the 2.5" NA seems to be the only one mating up to the tullet cat flange.
U-bends from other brands seem to be useless.
Very frustrated with that, as that kitty is sold as compatible. In my book it's not.
#1268
Posted 07 April 2013 - 02:27 PM
#1269
Posted 07 April 2013 - 02:33 PM
#1270
Posted 07 April 2013 - 02:39 PM
#1271
Posted 07 April 2013 - 02:41 PM
#1272
Posted 07 April 2013 - 02:44 PM
#1273
Posted 07 April 2013 - 02:46 PM
I had the tullet flange re-welded to fit the OEM position cat section flange. As smily said it will be the Tullet not Miltek that is wrong!
By how many degrees did you rotate it?
#1274
Posted 07 April 2013 - 02:49 PM
I have tried an oem and a janspeed u-bend.
They don't line up to the tullett cat flange.
If i put the oem or janspeed u-bend in the cat flange pointing to the front of the car, it fits.
The tullet flange on both the u-bend and the are twisted exactly 1/3rd by design it seems. (so they only mate with each other)
1/3rd rotation should be fine shouldn't it? It isn't out by a third, more like 5%
#1275
Posted 07 April 2013 - 02:55 PM
I have also found the tullet bolt fixings to be not exactly in the OEM position, but with a full tullet all is fineI had the tullet flange re-welded to fit the OEM position cat section flange. As smily said it will be the Tullet not Miltek that is wrong!
#1276
Posted 07 April 2013 - 02:56 PM
with a nice slip joint at one end
Whats one of them?
#1277
Posted 07 April 2013 - 03:00 PM
#1278
Posted 07 April 2013 - 03:04 PM
#1279
Posted 07 April 2013 - 03:09 PM
#1280
Posted 07 April 2013 - 03:16 PM
Bing (2)
