Project Jg
1783 replies to this topic
#1281 CocoPops
CocoPops
  • 17,182 posts
Posted 07 April 2013 - 03:18 PM
I don't use that flange mount on mine.
#1282 smiley
Posted 07 April 2013 - 03:32 PM
This is the tullett and the oem showing the problem.
You're right JG, it's only a few degree off.
Edited by smiley, 07 April 2013 - 03:35 PM.
#1283 oakmere
oakmere
  • 2,143 posts
Posted 07 April 2013 - 03:47 PM
I had the tullet flange re-welded to fit the OEM position cat section flange. As smily said it will be the Tullet not Miltek that is wrong!
By how many degrees did you rotate it?
I just marked up on the flange where the holes needed to be and handed it over to the fabricator £15.00 later all done.
#1284 JG
JG
  • 13,612 posts
Posted 07 April 2013 - 04:08 PM
I've just done exactly that.
I'd be cautious about blaming the tullet too quickly. It fitted fine with my oem u bend.
Either way, this is how far out the the holes are. (my pencil marks)
But the Milltek U-bend isn't very well made. Its out of square (by quite a long way, more than i can show in that picture). Its brand new, so i could sent it back, but since i'm going to modify it, i might as well keep put up with it:
That would be why it doesn't fit very well :rolleyes:
#1285 JG
JG
  • 13,612 posts
Posted 07 April 2013 - 04:12 PM
I think the Oem mounting on the NA can put up with that due to the short radius. but that does look about the same as the mark up i've done on the u-bend
#1286 JG
JG
  • 13,612 posts
Posted 07 April 2013 - 04:15 PM
On the plus side, the fuel system just primed up beautifully :D
#1287 smiley
Posted 07 April 2013 - 04:19 PM
Tullett cat, with oem u-bend connected to what backbox?
#1288 JG
JG
  • 13,612 posts
Posted 07 April 2013 - 04:36 PM
NA Milltek back box, which is virtually the same as oem.
#1289 ArticMonkey
ArticMonkey
  • 4,792 posts
Posted 07 April 2013 - 07:10 PM
AMD had no issue fitting my tullet cat to the miltek u-bend. Friday afternoon job by one of them? Did I read that you'll be offering the complete fuel system kit and fixings as a package on mango JG?
#1290 oakmere
oakmere
  • 2,143 posts
Posted 07 April 2013 - 07:56 PM
I don't think all the Tullets are like this maybe just the early ones. From memory the early manifolds didn't fit either! I think all these exhausts are quite poorly made for the money charged.
Edited by oakmere, 07 April 2013 - 07:59 PM.
#1291 smiley
Posted 07 April 2013 - 08:06 PM
That shiny ubend from the pic, came in a box from tullett this week.
#1292 JG
JG
  • 13,612 posts
Posted 07 April 2013 - 08:23 PM
I do have a list now of all the items required. the only problem is that i think installation gets a pretty high rating on the haynes spanner list. :lol:
Not sure how AmD installed yours, I think i could make it fit (just) but wouldn't be ideal. However given the tolerances to which these things are make its quite conceivable that yours was close enough to fit.
#1293 oakmere
oakmere
  • 2,143 posts
Posted 07 April 2013 - 08:25 PM
Like i said not great for the money, the jigs must be made of plasticine.
#1294 JG
JG
  • 13,612 posts
Posted 10 April 2013 - 07:43 PM
frankenstein u-bend. Not wonderful i know, but at least its now square and pointing in the right (or wrong) direction.
#1295 JG
JG
  • 13,612 posts
Posted 11 April 2013 - 07:25 PM
Now fits perfectly, including using the mounting :D
#1296 CocoPops
CocoPops
  • 17,182 posts
Posted 11 April 2013 - 07:35 PM
And.....? Noise levels?
#1297 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 11 April 2013 - 07:39 PM
Spray it with some heatproof paint... isn't that the way most aftermarket exhaust companies hide their welding.
#1298 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 12 April 2013 - 09:08 AM
Heatproof paint! Just cheap standard silver paint so that it burns off first time the exhaust gets hot on any aftermarket exhaust I have ever seen or had!
#1299 JG
JG
  • 13,612 posts
Posted 12 April 2013 - 10:54 AM
ya, its fine as it is :)
#1300 JG
JG
  • 13,612 posts
Posted 12 April 2013 - 05:43 PM
Nearly back to OEM :lol:
    Bing (1)
