Project Jg
1783 replies to this topic
#1321 vocky
Posted 14 April 2013 - 04:07 PM
I'm pretty sure you put it like that :P :lol:
But i suppose i'll move it :D
I would have done ...... when you had a standard manifold with the factory heat shield :P
I always alter them for the 4-1 tubular manifolds ;)
#1322 JG
JG
  • 13,612 posts
Posted 14 April 2013 - 06:42 PM
Keep me posted James. I tried to get some info on the very same thing last year but got nowhere with them. Moving to a fully enclosed filter made a decent difference to mine at Le Mans last year. I went plastic though as I wasn't sure whether a carbon or aluminium one (based on previous ITG experience) wouldn't just resonate and add to the general racket.
well, we put one on Lee's car today, and given that his car actually works were able to try it. and erm, we think it makes a difference :lol:
But it is small,10-20% maybe? It certainly isn't a night and day effect. It isn't louder though thumbsup :unsure: :lol: and there is no itg woooshing (technical term) :lol:
Oh and my new Exhaust is stll quieter than Lee's :lol:
#1323 CocoPops
CocoPops
  • 17,182 posts
Posted 14 April 2013 - 07:05 PM
:lol:
#1324 Kart59
Kart59
  • 298 posts
Posted 15 April 2013 - 09:05 PM
can find the pic of a new one, but here is a broken one. flat bit should be...flat.
ahh i see, does that bracket push your exhaust away from the subrame? Mine sits alot closer to the sub frame than yours in the picture, just hope it dosnt bang into it over bumps.
#1325 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 15 April 2013 - 09:06 PM
Fuckbuckets... that's it.
#1326 JG
JG
  • 13,612 posts
Posted 15 April 2013 - 09:31 PM
It will be fine. Not all systems use that mounting and ive seen lots that are much closer :)
#1327 JG
JG
  • 13,612 posts
Pardon? :blink: :lol:
#1328 JG
JG
  • 13,612 posts
Posted 24 April 2013 - 09:18 PM
Finally got a fan switch fitted.
Thanks to lee for the pointers.
switch wired to a plug
plug wired into the loom
earth to the gear level holder
and finally
#1329 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 24 April 2013 - 09:19 PM
Not very OEM James.
#1330 JG
JG
  • 13,612 posts
Posted 24 April 2013 - 09:24 PM
indeed, but it was the least intrusive thing i could think of :P
#1331 techieboy
Posted 24 April 2013 - 09:32 PM
Is that an LED in the switch? Does it work? I find that at least 50% of the time I've manually triggered the fan, I leave it running when back up to speed. :wacko:
#1332 fezzasus
I would have deleted the immobiliser LED and put a switch there instead. But very tidy work none the less.
#1333 JG
JG
  • 13,612 posts
Posted 24 April 2013 - 09:37 PM
No, it doesn't.It could be made to work if you ran a wire to the relay. You can wire it so that the LED is on all the time and then off when the fan comes on, but that would probably we worse (thats because the switching is done via an earth rather than a live)
#1334 techieboy
Posted 24 April 2013 - 09:39 PM
Twas what I expected. thumbsdown
Need to work out how to convert my defunct front fog light switch to manually run the fan. :unsure:
#1335 chris_uk
Posted 24 April 2013 - 09:40 PM
looks alright tbh, maybe i would of put it on the light switch panel instead tho.
#1336 JG
JG
  • 13,612 posts
Posted 24 April 2013 - 09:52 PM
my centre console is destined for the bin so for the time being, i didn't mind sticking a hole in it thumbsup
#1337 nicollow
nicollow
  • 3,801 posts
Posted 24 April 2013 - 09:53 PM
That switch is in the same position as I put my bass adjust for my sub. OEM+ y'all!! :P
#1338 JG
JG
  • 13,612 posts
Posted 24 April 2013 - 09:56 PM
Also the heated seat switches have to go somewhere so thats another attack on OEMness.
#1339 nicollow
nicollow
  • 3,801 posts
Posted 24 April 2013 - 10:04 PM
I stuck mine under the cup holder ;)
#1340 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 24 April 2013 - 10:07 PM
Why do you need a fan switch when you can just use the scan gauge?
