Project Jg
1783 replies to this topic
#1541 JG
JG
  • 13,612 posts
Posted 20 December 2013 - 08:37 PM
It's the fact he parked in a shopping centre car park through choice that surprised me most!
I'm actually amazed i got into it, have you seen the raised obstacles to get into the John Lewis carpark?
#1542 JG
JG
  • 13,612 posts
Posted 01 January 2014 - 07:19 PM
Fitted a new spoiler thumbsup
#1543 gingerjon
gingerjon
  • 587 posts
Posted 01 January 2014 - 11:50 PM
I don't think that one is mounted far enough back to generate the correct levels of downforce JG........
#1544 JG
JG
  • 13,612 posts
Posted 18 January 2014 - 06:05 PM
Yay a few new toys, a long time since that has really happened:
To go with a set of these as a 308 (J-hooked (you can have whatever you want) for fannies like me :P :D):
And one of these...
...to evaluate OBDtuner :)
#1545 CHILL Gone DUTCH
Posted 18 January 2014 - 06:07 PM
When the ECU comes back it will have parcel tape over the plug pins
#1546 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 18 January 2014 - 06:15 PM
Oh wow, I didn't realise you'd found some 308 rotors at a decent price (I'm assuming you paid the £245 it says on their site?)
This post makes me happy, I want some new rotors for my AP kit :)
#1547 JG
JG
  • 13,612 posts
Posted 18 January 2014 - 06:27 PM
yep :) You have to thank Tom (Mr Fez). He found them.
You'll need a 190 PCD with your AP Bells (rather than the 177 i ordered to go with the Plans Motorsport Bells i have)
This is quite a good chart:
#1548 JG
JG
  • 13,612 posts
Posted 18 January 2014 - 06:52 PM
ok... :unsure:
#1549 JG
JG
  • 13,612 posts
Posted 18 January 2014 - 06:59 PM
Oh and i also got a new set of AP bolts, nuts and washers (don't go with any alternatives) for £16 a set. Also supplied by Reyland.
#1550 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 19 January 2014 - 11:59 PM
According to the original AP specs, their discs are 26mm new and replaced at 24mm. These are only 25mm when new, so I'm hoping they're able to widthstand the applied forces when they get down to 23mm
#1551 chris_uk
Posted 20 January 2014 - 01:12 AM
I need new discs so might get some of these.
#1552 Bargi
Bargi
  • 4,483 posts
Posted 20 January 2014 - 03:42 AM
Is this with a 4 Pot setup or will it go onto the standard AP kit?
#1553 JG
JG
  • 13,612 posts
Posted 20 January 2014 - 06:48 AM
Correct, but the Astra GSi disc we all use with the 4 pot is 25mm too. So 25mm will be fine. A 1mm wear lip is actually quite a lot and you can get three sets of the reyland rotors for the price of ap ones. Sure, the iron quality may be a bit weaker but I'll never notice. At worse they will wear a little bit faster. Ray, these are indeed for the 4 pot (BBK) setup, but would also work with a 288 rotor or standard ap calipers and spacers ( you could go for 295s with smaller spacers)
#1554 Gedi
Gedi
    404 Not Found
  • 5,547 posts
  • Interests:Nothing
Posted 20 January 2014 - 10:17 AM
I've just done a wee bit of reading and it appears the Astra 1.9 CDTi (which uses the 308 discs) are rated at 25mm new and 22mm minimum. I'm pretty sure if that's the spec for a car ~500kg's heavier than ours, then we shouldn't have any problems with 25 -> 23. However, I'll double check with reynolds just for piece of mind.
#1555 JG
JG
  • 13,612 posts
Posted 20 January 2014 - 06:53 PM
And in lightning fast time:
:D
#1556 JG
JG
  • 13,612 posts
Posted 20 January 2014 - 06:58 PM
Btw, it appears that the base disc is a Pagid disc.
#1557 fezzasus
Posted 20 January 2014 - 09:12 PM
Good to know, do you have a side shot of the veins?
#1558 JG
JG
  • 13,612 posts
Posted 20 January 2014 - 09:56 PM
Not as pretty as an AP, but good enough
#1559 JG
JG
  • 13,612 posts
Posted 20 January 2014 - 09:57 PM
5.25kg for the rotor on its own.
#1560 2GOOD
2GOOD
    Old Timer zzz...
  • 4,451 posts
Posted 21 January 2014 - 08:27 AM
If it makes any difference, according to the owner of performance braking in Monmouth. Pagid themselves don't make their own discs, it's just a deal done with the name.
    Google (1)
