Rain Shield?
Posted 21 October 2005 - 08:47 AM
Posted 21 October 2005 - 09:03 AM
Posted 21 October 2005 - 11:08 AM
It’s been out in the rain a few times at work. Is it worth getting those 'getbadass' covers?
http://www.getbadass.com/vx220.htm
I don’t want to experience the dreaded Engine Management light scenario, on a cold December morning!
#4 Guest_AntB (Guest)
Posted 21 October 2005 - 11:26 AM
there is a separate issue with turbos due to the ecu location and the design of the cam cover.I have a 01 N/A
i have the badass cover as i have had my na fcuk up. money well spent
to my knowledge, it is a warranty issue, get vxl to do it NOW.
any turbot owners care to add further comment?
i've had SO many problems with water ingress on my vx i will be BUYING a turbo rain cover and having it fitted a well as the badass cover, just to be sure.
on properly designed cars, the problem is avoided with bonnet!
I asked why and they said it was not needed on my car
to be read as; "we forgot/ couldn't be bothered" ?
Edited by AntB, 21 October 2005 - 11:39 AM.
Posted 21 October 2005 - 12:51 PM
Turbo rain cover won't fit on an NAi've had SO many problems with water ingress on my vx i will be BUYING a turbo rain cover and having it fitted a well as the badass cover, just to be sure.
My dealership tried (i asked them not too) and i have the drill holes and scruffs to prove it won't fit
#6 Guest_AntB (Guest)
Posted 21 October 2005 - 01:11 PM
julie notedTurbo rain cover won't fit on an NAi've had SO many problems with water ingress on my vx i will be BUYING a turbo rain cover and having it fitted a well as the badass cover, just to be sure.
Posted 21 October 2005 - 01:17 PM
Posted 21 October 2005 - 01:19 PM
Posted 21 October 2005 - 01:21 PM
Posted 21 October 2005 - 01:22 PM
yes thats the bad boy - and its not the same on the NA as the parts affected are in a different place and not so exposedit's on the bonnet isn't it? A black cover thing under the grille
Posted 21 October 2005 - 01:27 PM
Posted 21 October 2005 - 01:32 PM
Posted 21 October 2005 - 02:13 PM
Posted 21 October 2005 - 02:14 PM
Posted 21 October 2005 - 02:18 PM
The Turbo's have a black rain shield on the bonnet cover, the NA doesn't have one and it can't be fitted on the NA apparently.Sorry to be an idiot but should I be worrying about having something similar fitted for my na? Or is it only the turbots that have the problem?
Help
The Badass cover covers the electrics at the head and prevent water getting in there.
Don't know about the coil pack, which could also be badly affected by water ingress. Not all NA's suffer problems caused by water ingress so it's not neccessary, but a lot have, so it may be worth getting
HTH
Posted 21 October 2005 - 02:21 PM
Posted 21 October 2005 - 02:45 PM
So there is an official 'bit' for the N/A's that stops water ingress then?yes thats the bad boy - and its not the same on the NA as the parts affected are in a different place and not so exposedit's on the bonnet isn't it? A black cover thing under the grille
#18 Guest_AntB (Guest)
Posted 21 October 2005 - 02:48 PM
Can i be stupid and ask what good the badass cover does ?
My cars problem was caused by water getting into the coil pack, which is still unprotected even if you get both badass covers.
it protects the loom and ecu and throttle bodies etc
when i get 5 minutes i'll take a pic of mine. because ever since i got it i can sleep soundly at night when it's raining
unfortunately my company is trying to kill me with work at the moment so i haven't got time
aimed not at LD btw
Edited by AntB, 21 October 2005 - 02:49 PM.
#19 Guest_AntB (Guest)
Posted 21 October 2005 - 02:50 PM
no, it's aftermarketSo there is an official 'bit' for the N/A's that stops water ingress then?
talk about can open worms everywhere
Posted 21 October 2005 - 03:58 PM
thats the part for the VXT rework
