Edited by rubber, 22 October 2005 - 07:05 PM.
Posted 22 October 2005 - 05:56 PM
Posted 22 October 2005 - 06:02 PM
Edited by rubber, 22 October 2005 - 07:06 PM.
Posted 22 October 2005 - 06:07 PM
Edited by rubber, 22 October 2005 - 07:07 PM.
Posted 22 October 2005 - 06:10 PM
Posted 22 October 2005 - 06:52 PM
Fitted them todayThe problem is in fitting them - you need to do a good job of it.
Some of you will have the luck-of-Jobe, in that you'll just unscrew the old one and screw the new one in. It'll probably fit first time, and you won't loose all the numberous washers down behind the trim or worse - in the sills.
Most of us will be less lucky!
Posted 23 October 2005 - 11:45 AM
Posted 23 October 2005 - 12:16 PM
Posted 23 October 2005 - 04:06 PM
Edited by benw, 23 October 2005 - 04:10 PM.
Posted 23 October 2005 - 04:11 PM
Posted 23 October 2005 - 04:13 PM
Edited by benw, 23 October 2005 - 04:13 PM.
Posted 23 October 2005 - 04:14 PM
Posted 23 October 2005 - 04:52 PM
Hi , Im Nigel the guy behind the pins that fit and Steve has generously put me in touch with you all. I am basically a Lotus owner however I did have a VX on order but delay of delivery (one of the first ) meant I cancelled and went for Lotus and so it goes. Anyway it would appear that me advertising is verbotten but Steve has done that for me - Thanks. I have a batch of these available and will see how it goes before reinvesting, at the moment there is no immediate shortage. I normally flog on ebay and contrary to the quote I dont think they are all gone ? There are more. Anyway if you prefer to deal direct then I will in UK but Ebay is easier really. Happy to answer any questions but having over many months personally tested many different variants this is the final product.Sorry everyone but the ones Steve highlighted on eBay are gone now
Just wondering Steve, do you rekon a strong magnet would be sufficient to keep the washers and captive nut in place whilst you remove the old pin and fit the new one? For that matter, are they magnetic!!?
EDIT: Not the aluminium washers obviously!
Posted 23 October 2005 - 06:56 PM
Hi Nigel and welcome!Hi , Im Nigel the guy behind the pins that fit and Steve has generously put me in touch with you all. I am basically a Lotus owner however I did have a VX on order but delay of delivery (one of the first ) meant I cancelled and went for Lotus and so it goes. Anyway it would appear that me advertising is verbotten but Steve has done that for me - Thanks. I have a batch of these available and will see how it goes before reinvesting, at the moment there is no immediate shortage. I normally flog on ebay and contrary to the quote I dont think they are all gone ? There are more. Anyway if you prefer to deal direct then I will in UK but Ebay is easier really. Happy to answer any questions but having over many months personally tested many different variants this is the final product.
Cheers
Posted 23 October 2005 - 07:10 PM
Posted 23 October 2005 - 07:21 PM
In a nutshell, yes. I guess it could be possible to get the door shut again - you'll just have to do it all back up minus a washer or two which isn't ideal and means it's loose.So do I read the above correctly - you have to take the rear trim off to do the job?
If I don't and i lose a washer I take it the door won't stay closed? Thats a big risk to take
Posted 23 October 2005 - 07:38 PM
Posted 24 October 2005 - 06:26 AM
Posted 25 October 2005 - 05:14 PM
Posted 25 October 2005 - 11:54 PM
Posted 26 October 2005 - 07:49 AM
