How Many VXRs Are Left From 65.
599 replies to this topic
#581 hairy
hairy
    Moonlander
  • 6,019 posts
Posted 29 July 2020 - 06:45 PM
Welcome to .org chinky chinky
#582 cwhite2
cwhite2
  • 224 posts
Posted 30 July 2020 - 06:23 PM
Any luck with sourcing the badges for No 50 mate?
#583 900fc
900fc
  • 26 posts
Posted 31 July 2020 - 12:50 PM
Good morning,
I now owns VXR36 and will send shortly updated description of it. Being service at Type116 Motorsports as we speak.
Also converted my VXT red stage 4 in VXR clone using part from VXR51.
Cedric
#584 Cavturbo
Cavturbo
  • 387 posts
Posted 31 July 2020 - 04:43 PM
Hi Cedric, nice car. Are you based in Mexico or have I misunderstood?
#585 wilksy
wilksy
  • 21 posts
Posted 01 August 2020 - 07:15 PM
I’ve had to compromise on the badges, the front Griffin badge is 90mm in diameter the best I’ve found is 80mm diameter that will be fixed tomorrow. The rear badges have been I bit of a mission the Griffin badge is genuine VX220 bought from Germany, the VXR badge had been fitted to the front(?) which I’ve removed and will be repainted the flash with Calypso Red touch up paint and 3M tape reapplied, the 220 I just could not source so I’ve bought a Merc E220 rear badge and will use just the numbers, they are 25mm high which is the same as the VX letters, should get that on tomorrow as well - will post pictures.
#586 900fc
900fc
  • 26 posts
Posted 01 August 2020 - 09:19 PM
I am currently working in Mexico but my VXs are kept in France
#587 Cavturbo
Cavturbo
  • 387 posts
Posted 02 August 2020 - 03:33 AM
You have more than one?
#588 hairy
hairy
    Moonlander
  • 6,019 posts
Posted 02 August 2020 - 04:57 PM
What happened to the Moonland and Coral Blue examples (one of each)? :huh:
I think the Moonland one has been modded and used as a track car. I don't know about the Coral Blue one.
#589 wilksy
wilksy
  • 21 posts
Posted 02 August 2020 - 05:53 PM
So here is a couple of pictures of my rebadged VXR, as above I have had to compromise but overall it looks ok
#590 Strugs
Strugs
    World's #1 cheese fan
  • 3,008 posts
Posted 03 August 2020 - 05:25 PM
Knew the chap that owns the Moonland one. Haven't seen him for ages but he still has it. Was running 300 bhp ten years ago and I suspect more now..
Edited by Strugs, 03 August 2020 - 05:26 PM.
#591 Cavturbo
Cavturbo
  • 387 posts
Posted 03 August 2020 - 05:37 PM
I think there is a guy on the Facebook page who owns the coral vxr has a highly modded red vx too
#592 sford
sford
  • 1,451 posts
Posted 04 August 2020 - 09:15 AM
Last I recall is Dave Hardwick owns the blue VXR, along with Simon's (MrSimba) old black VX220T.
#593 cwhite2
cwhite2
  • 224 posts
Posted 04 August 2020 - 06:30 PM
Looking good Wilksy - that VXR badge really didn't look right on the front.
#594 wilksy
wilksy
  • 21 posts
Posted 05 August 2020 - 05:15 PM
Cheers couldn’t agree more the one that was on the rear seems to be proper VXR badge as well but with the red flash removed which is a shame
#595 keithives
keithives
  • 3 posts
Posted 07 September 2020 - 10:01 AM
Hey all, I've had number 62 since July or  August 2018,  VIN 7661. It spent 6 months at Courteney being fixed, now a beautifully sorted VXR.
#596 Cavturbo
Cavturbo
  • 387 posts
Posted 07 September 2020 - 07:23 PM
Wow, what did you have done at Courtenay?
#597 keithives
keithives
  • 3 posts
Posted 12 September 2020 - 04:24 PM
I think pretty much everything. I'm not particularly mechanically technical but from what I remember:
- full engine rebuild:
- replacement pistons
- something to do with rods being replaced with steel ones (any clues???)
- balancer shaft removal
- better clutch - supposed to be heavier than the original, but I can't tell - does Helix Organic make any sense?
- all bearings replaced
- flywheel replaced with lighter variant
It already had a Milltek exhaust - if it had the standard one, they'd have swapped it out for another type, but I didn't see the point in replacing a replacement for a marginal gain. Any views on a 'better' exhaust?
All in all, I'm v. happy. When I bought the car, the throttle response wasn't ideal - there was a huge, and often alarming, power drop around 4k revs. - hence wanting the engine to be sorted. The maps below show the differences. I'm currently driving on 'run-in' settings, final tuning will be in a few months (at which time I'm told there will be a minor uplift). Blue is old, red is new, post engine work.
Attached File  Ives Dyno.pdf   318.84KB   12 downloads
#598 Cavturbo
Cavturbo
  • 387 posts
Posted 12 September 2020 - 05:04 PM
Wow sounds extensive and expensive. You have the basis for.some good power there if you want it.
#599 RPM
RPM
  • 60 posts
Posted 10 August 2021 - 06:13 PM
Hi just bought No 14, vin 7566.Only has done 10k miles and has been living its life as a garage queen.
#600 ditonics
ditonics
    Turbos aren’t as good as NA’s
  • 939 posts
Posted 10 August 2021 - 07:41 PM
Time to rag it round a track. 😁
