Looks like he has junked the standard DIS and coils. You can see two coils mounted externally on the left side with plug leads running under the standard coil pack cover. One of my future mods, intend to connect some MSD coils to my MSD DIS-2. He has also maintained the standard ECU. The Emerald is mounted behind it.
Yep but why ?
Emerald ECU's cannot deal with the DIS ?
I do not understand where is the interest on replacing the DIS with a standard ignition system ?
Well - Something like the MSD DIS-2 gives a better/stronger spark plus a longer spark duration than a standard DIS pack. With the extra air and fuel in the cylinder it could be a good route to take. Also he probably wants to program his own timing table and unless he has the software to program the standard ECU (highly unlike coz he is running with an Emerald) it take a bit of rewiring and jigging about with the standard DIS and coil pack
Edited by speedster, 12 June 2006 - 09:39 PM.
