lol......get your car cleaned.....looked terrible
Webcons dyno had it measured at 215bhp running on a 85% finished map.
At what RPM and what torque?
Posted 15 October 2006 - 02:15 PM
Posted 18 October 2006 - 08:41 AM
No, there are two basic kits, one for a standard car and one for a stage 3 car with ported heads and cams. The kits are the same price for both, the only difference is the inlet port sizes, the ECU mapping and a few other proprietary bits.
Posted 18 October 2006 - 09:48 AM
Posted 18 October 2006 - 07:20 PM
Either really. THe TB kit does include an ECU and a different map so that duplicates a stage 3 to some extent but mechanically there's no duplication.
Posted 19 October 2006 - 03:44 AM
Posted 19 October 2006 - 08:23 AM
Posted 19 October 2006 - 02:51 PM
Posted 19 October 2006 - 03:09 PM
Posted 19 October 2006 - 03:47 PM
Don't think you will be able to have an ITG and TB's??
But I could be wrong...
Posted 19 October 2006 - 07:40 PM
Don't think you will be able to have an ITG and TB's??![]()
Maybe 4 very small ITG's?
Posted 19 October 2006 - 09:47 PM
Posted 20 October 2006 - 05:00 AM
Posted 20 October 2006 - 07:48 AM
Posted 20 October 2006 - 08:00 AM
Sure you can.
Depends a bit on the hose diameter, but ITB setups usually still use a plenum setup where the air is drawn in through one big airfilter and then distributed to the TB's.
Separate air filters on each TB is not that useful in a mid-engined setup as you end up sucking in lots of hot air from under the hood. Less of an issue in front engined cars, or cars where the TB's stick through the hood (eg. often on seven clones).
Posted 20 October 2006 - 11:16 AM
Posted 20 October 2006 - 12:02 PM
Posted 20 October 2006 - 06:27 PM
Posted 20 October 2006 - 07:36 PM
We want to fit the kits to a couple of cars and use the dyno charts from all of them before we announce intricate details, no point just using one car its not representative of what the kit can do, but yes its in prodcution as we all think its perfect.
Posted 21 October 2006 - 09:37 AM
Posted 21 October 2006 - 01:03 PM
