Throttle Bodies
#401
Posted 16 February 2007 - 09:08 PM
#402
Posted 16 February 2007 - 09:15 PM
No, we can't run TB's on class A cars. The VX's were moved from B to A as the Class B had shrunk to only 3 other cars, a 340r and 2 S1 Elises with NA Honda conversions. Whilst I was happy that we could compare on power (once the race cars were to up spec which at Brands they weren't) but it made little point, the VX's weighed in at 850kg's (complete with cage and safety equipment) but the Hondas weighed in at 700kg's and there's no way we could get the VX's down to 700kg's so we moved.
Ah I see - makes sense. The S1's are very light especially if they are running with A frames as opposed to full cages and although the VX's will still be running at a weight disadvantage in Class A at least there are more people to play with in that class !
Looking forward to seeing you mix it up with the other big boys toyz in Class C too
Roll on the 24th of March
#403
Posted 16 February 2007 - 09:25 PM
#404
Posted 16 February 2007 - 09:45 PM
Are you on Thorney's payroll?
errrr.... nope!
Just saying it as i see it to be honest mate.. thats all!
Some people just cant help themselves... proper chip on there shoulder/short arse syndrome etc..never have anything constructive to say about new ideas/developments...
G.
you may need to have a look at the history.....for me i have been instrumental in getting the following sorted for the vx..spax rs shocks, itg induction, my car helped in the development of the regal/stealth exhaust system(including exhaust manifold) it has also been used as the mule for eds/regal remapps for the na...also was the first to have the racc logic traction control system! there are other things that i have looked into for the vx too....
i approached a company about throttle bodies back in 2004 and they wanted to have my car for 3 months to develop a throttle body setup but at that time i wanted to use my car as it was my only form of transport...18 months to deliver a product seems to be a long time thats all
to me to get a decent amount of power from throttle bodies you need to move the power band up on the cams...240+bhp is possible but you will find that the car will be difficult drive below 3000rpm...
it seems that to get a decent linear power delivery then supercharging is the way to go.....
ps i may be short but i dont think i have short arse syndrome.....
and pps my other car is a porsche cayman s which is due for upgrades!
#405
Posted 16 February 2007 - 10:13 PM
errrr.... nope!
G.
I was just stateing the obvious..!!! Anything TMS seem to do.. you have a sarcastic dig...??? Ive not seen it the other way?? Incidently its not just on the throttle body thread!
Im not that technical or knowledgeable on engines etc... but i would say to get a good throttle body set up to be the best of both worlds (road and track use) alot of R&D is necessary?? Its not just a question of bolting things on&fingers crossed hope this works???
I remember a certain tuner Steve Broughton put a lot of work into the Jenvey throttle body kits he did for vauxhalls 2.0XE which proved very successfull in westfields / carterhams etc he did the same for vauxhalls 1.6 16v on throttle bodies.. nearly 240bhp!
Am i supposed to be impressed that you own a Cayman S?? Actually..Can you see over the steering wheel ok?? LOL!!
If you want to compare cars.. a mate of mine has a 360 Challenge Stradale!
G.
#406
Posted 16 February 2007 - 10:21 PM
#407
Posted 16 February 2007 - 10:36 PM
Edited by clipping_point, 16 February 2007 - 10:37 PM.
#408
Posted 16 February 2007 - 11:07 PM
ive got a corsa 1.4 from 1994, it almost falls over when i overcook it on roundabouts - does this count ?
I've got a Corsa 1.4 1997
( and it's bloody lethal on Roundabouts esp. after driving the VX and forgetting to slow down enough!)
#409
Posted 17 February 2007 - 02:40 AM
#410
Posted 17 February 2007 - 03:09 AM
Actually... That's the whole reason for going to individual TB's.
Mapped properly they should give a rock-steady idle and pull smoothly all the way from idle to the rev lmiter.
Of course if wilder cams are used they will have a stronger off and on cam feeling, but they should still not drop torque at low rpm's compared to the standard setup. Perhaps a little around idle and up to 1500rpm, but that's about it. (good 4-2-1 manifold with loooonggg primaries and secondaries can help to claw back torque too)
Experiences on the Elise with the K-series and throttle bodies (and Emerald ECU's) shows that you can run ridiculous cam profiles that make power up to 9000rpm before dropping off and still keep the car perfectly driveable.
Biggest requirements for this are:
- Spot-on cam timing (pretty much any wilder cam will need manual timing with either vernier cam wheels or offset dowels to be correct)
- Well executed ECU mapping
Get it wrong (like Lotus proved so well on the S1 Exige and 340R with the 190HP K series
#411
Posted 17 February 2007 - 05:55 AM
#412
Posted 17 February 2007 - 07:23 AM
#414
Posted 17 February 2007 - 08:16 PM
#415
Posted 17 February 2007 - 08:34 PM
#416
Posted 17 February 2007 - 10:02 PM
which is always on the track, and believe meis driven to its limits, both here and abroad, Spa, Nurburg etc..
G.
...and I bet your Dad is bigger and meaner, too
#417
Posted 17 February 2007 - 11:08 PM
We use a plenum on the kits which is CNC machined and looks lovely. The problem with running long trumpets is the space we have before we hit the firewall but there's room enough for decent set up. Current dyno runs range from 185bhp (on our dyno) to 225bhp on another dyno so depending on what you believe the numbers are there. However, until its official (ie I can replciate it on multiple cars on multiple dynos) its still subject to confirmation.
Hi John, thats with cams and stuff or just tb's and milltek ?
#418
Posted 18 February 2007 - 02:13 AM
#419
Posted 18 February 2007 - 09:01 PM
185 BHP with 50.8 mm dia tubing for the exhaust is not bad.
+1, 185 BHP on standard exhaust and cams sounds good enough.... but i think this dyno was done with schrick cams and a more freeflowing exhaust...
#420
Posted 19 February 2007 - 01:30 AM
50.8 mm is the diameter of the NA Milltek on the VX.
The stock dia on the VX is 1'' 7/8 . And for you information, it is the same dia as a 1.6 liter MX5 (1991, 115 Bhp ) and it is considered restrictive on this car.
Bing (1)
