Throttle Bodies
#641
Posted 05 June 2007 - 06:37 PM
#642
Posted 05 June 2007 - 06:40 PM
#643
Posted 05 June 2007 - 07:16 PM
#644
Posted 05 June 2007 - 08:35 PM
#645
Posted 05 June 2007 - 09:54 PM
Notice also how much flatter then lines are for the TB (smoother power delivery) and how there is hardly any tapering off at the top end -- in my opinion its these kinds of differences that add extra value to the package (over and above the x BHP increase).
Note the scaling on my torque graphs, my run is pretty smooth too. I'm between 140 and 167 lb ft across the most of rev range plus appear to be making more high end torque than the iTB's. Torque starts tapering off from 165 lb ft at around 5000'ish, I'm hitting the limiter (low setting) at around 130 lb ft at (I was lean above 5200 RPM on this run).
The iTB's appear to be running between 140 and 152 lb ft across most of the rev range, tapering down from 140'ish lb ft at 5600'ish ending up at 122 lb ft.
Not much different between iTB's and my single 68mm... Wonder how we will fair out with cams?
#646
Posted 06 June 2007 - 05:28 AM
#647
Posted 06 June 2007 - 06:31 AM
......... Supply only kit price should be sorted today, working with Webcon to reduce the price a little (depends on their suppliers fixing some of the componant prices). .....
Any new on this John? Cheers.
#648
Posted 06 June 2007 - 08:05 AM
#649
Posted 06 June 2007 - 11:49 AM
At the moment i am trying to work out the difference between
just buying a turbo or vxr, super charger or ITBs.
Would it be possible to find a brief rundown somewhere or have a guide as i find it all rather confusing at the moment.
im interested in the speed (obviously) power delivery, relyability, tunability, etc.
Ah, i see you are after the holy grail of the this thread.
There is little or no information about how VXR, ITBs or supercharged NA compare unfortunately. The only way to get a decent idea is to get three cars to the same dyno on the same day and run the numbers.
The other other way is to get someone impartial who has driven all three to give his opinion - very unlikely to happen unfortunately...
Ta,Paul.
#650
Posted 06 June 2007 - 12:08 PM
#651
Posted 06 June 2007 - 01:04 PM
#652
Posted 06 June 2007 - 05:42 PM
ffs, put the fecking power and torque on the SAME axis resolution! makes working things out far easier
Create an account and stick 'em on http://www.dyno-plot.../dyno/about.htm
Makes it easy to compare to any other car/engine as well.
Eg. a Westfield with a 2.0L XE Opel/Vuaxhall engine does this:
http://www.dyno-plot...chards-Bros.htm
Edited by Arno, 06 June 2007 - 05:44 PM.
#653
Posted 06 June 2007 - 10:07 PM
#654
Posted 06 June 2007 - 10:22 PM
#655
Posted 06 June 2007 - 10:39 PM
#656
Posted 07 June 2007 - 03:10 PM
#657
Posted 07 June 2007 - 04:13 PM
John?
#658
Posted 07 June 2007 - 06:51 PM
#659
Posted 07 June 2007 - 11:53 PM
I've just had an idea.
Lets get
a standard Na
a standard T
A VXR
an SC
an ITB
a stage 1 T
and a stage 2 NA
S/C Car ready here
#660
Posted 08 June 2007 - 08:07 AM
From what i read i understand the engine revs amost like a v-tec with TB's.
I had a Honda S2000 as my former car and i know shifting up at a high rev range was important to not loose power when your in the next gear.
The vx220 has only 5 gears...
So, my question is can you stay in that powerband when shifting up?
And what rpm (minimum revs) should you shift not to loose power?
Or does the vx220's torque means this isn't much of an issue?
RCduck7
I've not driven an S2000 unfortunately so I wouldn't be able to make the comparison.
When pushing i'm changing just before I hit the limit, but I wouldn't know for certain if I stay in the powerband or not, or how the torque effects things.
I know its good fun though
