Posted 05 March 2006 - 10:37 AM
Posted 05 March 2006 - 04:47 PM
Posted 05 March 2006 - 08:17 PM
Posted 05 March 2006 - 09:55 PM
Uh oh!The other thing is that my set came without the springs attached. I don't have a spring compressor so I couldn't pre-set the ride height and slide the spring on afterwards which I'd prefer to do. I had to wind the height adjuster all the way down, fit the spring, then wind back up again. It got too tight to adjust by hand after about 30mm of winding so I've had to install them lower than I planned (I think about 350mm). That means the handling will be out until I can get geo'd.
Posted 05 March 2006 - 09:56 PM
Posted 05 March 2006 - 11:37 PM
You have fitted the springs correctly but to wind them up tight is going to give you a massively increased ride height!
These springs are unlike the standard items in that they have barely any static sag due to the increased spring rate and more linear spring characteristics!
To wind them up tight will give you an increased ride height over standard!![]()
Posted 08 March 2006 - 03:53 PM
Edited by benw, 08 March 2006 - 03:54 PM.
Posted 08 March 2006 - 03:58 PM
Posted 08 March 2006 - 04:01 PM
Bloody hell. I would have taken the bus. I don't operate at 6am so I would definately not be up to fitting the rest of a suspension setup at that time.By the way, just thought I'd mention that I did manage to get the final one on. Had to get up at 6am to finish the final one in time to go to work at 7!!
Posted 08 March 2006 - 07:11 PM
Posted 08 March 2006 - 07:18 PM
Posted 08 March 2006 - 08:58 PM
YES!!I have received JohnyB's and my set today. Hooray.
Posted 08 March 2006 - 09:15 PM
You have a PMYES!!I have received JohnyB's and my set today. Hooray.
Will you be able to ship them tomorow to me ?
Posted 08 March 2006 - 09:22 PM
He said all the remaining sets ordered on the group buy were still with him. He didn't mention if they were built or not, sorry. I will keep my fingers crossed for you all that they arrive on Friday. One good thing is that I think they must be sending them direct from Spax so there won't be a delay sending the to POTN first, then to you.Did he mention the chances of the rest arriving by the weekend?
Posted 10 March 2006 - 09:55 AM
Posted 10 March 2006 - 04:04 PM
Posted 10 March 2006 - 04:23 PM
To get the spring in I had to wind the height adjuster all the way down. Once the spring was in I wound it back up by about an inch so there is an inch of black thread showing beneath the spring. I measured the amount of adjustment across the front and rear pairs to make sure I had them the same on either side.Ben, you said you had wound up the suspension, did you wind it back down any? Just wondering how much you compressed the spring by.
Edited by benw, 10 March 2006 - 04:24 PM.
Posted 10 March 2006 - 04:33 PM
Posted 10 March 2006 - 05:38 PM
Posted 10 March 2006 - 08:07 PM
350mm from where to where?EDIT: Winding up by an inch has produced a ride height of about 350mm so you'll need to go higher or lower depending on what you want the final ride height to be.
