As Promised - Spax Group Buy
#241
Posted 20 March 2006 - 02:35 PM
#242
Posted 21 March 2006 - 12:22 PM
#243
Posted 23 March 2006 - 11:20 AM
WOW
I am really taken aback as to how much difference a geo can really make. The car handles completely differently now, it's amazing. I have never felt confident with this car until now. You can point it where you want it to go and it does it without arguement.
I have read so many posts with people saying "this is the best mod I have done to the car" and always taken it with a pinch of salt, but I can whole heartedly agree with this opinion now.
The ride height on the car (my initial reason for doing this mod) has now been sorted out aswell. It looks really low and very cool. I had a quick look through the wheel to see how much thread had been used and as far as I can see the fronts are wound up roughly 8 to 10 mm.
I will do some more measurements and take some more pictures at the weekend (or tonight if it's still light) and post them up here.
#244
Posted 23 March 2006 - 11:33 AM
#245
Posted 23 March 2006 - 11:52 AM
Exactly what he said! My geo was done on tuesday and the difference is amazing- plus its pretty low nowHad the geo and ride height done yesterday.
WOW
#246
Posted 23 March 2006 - 12:57 PM
Standard n/a wheels and tyres.please god let there be light today
Do you have 16"/17" or standard wheels ?
Oh, Horizon told me to run 22 front and 24 rear tyre pressures now.
#247
Posted 23 March 2006 - 01:16 PM
#248
Posted 24 March 2006 - 12:12 PM
#249
Posted 24 March 2006 - 12:43 PM
#250
Posted 24 March 2006 - 02:31 PM
No idea on the settings. The only print out I got was the invoice.aha .. i have 16" fronts.. but i would still be glad if you post the ride heights (i can then compare it with my na wheel).
Did they tell you what geo settings they used ? (do you have a printout)
Mine's set up like this..
front:
0.25mm toe out
-1 degree camber
Rear:
2mm toe
-2mm degree camber
Castor they did not change since they didn't know how to - and i at the time did not also![]()
About the tire pressures.. i think i may be running a lot higher. will check now (have to pick up niece anyway)
I'm not sure about tyre pressures. I know the guy said 22 / 24 was the best for the particular geo I had but i'd imagine it would be different for another setup.
Richiemouse, corner weighting hey? Looks like you are getting the job done properly. You'll have to let us know what difference it makes.
#251
Posted 24 March 2006 - 02:38 PM
#252
Posted 25 March 2006 - 02:20 PM
Car before lowering:
Car after lowering:
Apologies for the crap quality, I was trying to make the height more obvious.
#253
Posted 25 March 2006 - 02:29 PM
Front before:
1 = 360mm
2 = 60mm
3 = 140mm
4 = 345mm
Front after:
1 = 340mm
2 = 35mm
3 = 120mm
4 = 322mm
Rear before:
1 = 345mm
2 = 38mm
3 = 140mm
Rear after:
1 = 333mm
2 = 20mm
3 = 125mm
#254
Posted 25 March 2006 - 03:09 PM
#255
Posted 25 March 2006 - 06:47 PM
Front suspension:
Rear suspension:
#256
Posted 25 March 2006 - 06:54 PM
#257
Posted 25 March 2006 - 07:01 PM
Yes I lubricated myself all over before fitting themDid you lubricate/oil/seal/wd40 them before fitting?
Seriously, the only bit of lubrication (I used grease) needed was on the rubbers at each end of the shocks. I found they slid into the mounts much more easily, especially at the front where you have the spacers to fit.
Seeing how much water has splashed up onto them already I am now thinking I should do something about protecting the adjusters. I might just cover the adjuster in it, hopefully this will give a waterproof barrier even if it doesn't look pretty.
edit: I suppose a bit of grease on the threads wouldn't go a miss either.
Edited by craglett, 25 March 2006 - 07:02 PM.
#258
Posted 26 March 2006 - 02:55 PM
#259
Posted 27 March 2006 - 07:00 AM
#260
Posted 27 March 2006 - 09:25 AM
I have set mine to 12 rear / 14 front but this is going to be a personal preference and may not even be my final setup.I'm missing how much front/back clicks do you have.
My thought process on it was:
1) Start with the standard recommendation of 6 rear / 8 front made by spax - take it for a drive.
2) Double the setting on the rear (12) and keep the difference of 2 front to rear (14) - take it for a drive.
3) This felt much better so I thought I would wait until the geo had been done before changing it any more.
4) Geo now done and it feels really good with these settings so I am going to leave them for a bit.
It kind of makes sense (to me at least) that the sweet spot on these things is going to be roughly half way through the available damping so around 14 clicks. At the moment this is about where I am.
Richiemouse, I agree with your thoughts totally. I could only really sum up the change as different and definately not better once I had fitted them. That was until I got the geo done of course. I would definately say the ride was better now as my post above suggests
Also Richiemouse, I am now resorting to driving onto a Yellow Pages before sticking the trolley jack under the car. It's a lot cheaper than the alternative method of buying a racing trolley jack for £120!!
