Comparing specifications of the standard Bridgestones to 205/50R17 Toyo T1-Rs:
Bridgestone Potenza RE040 Specs:
E040 BZ 175 / 55 R 17 81 W
Measuring Rim: 5 1/2
Overall Diameter: 624
Overall Width: 182
Static Loded radius: 291
Rolling Circumference: 1903
Toyo Proxes T1-R Specs:
205/50ZR17 93Y *
Rims: 5.5-(6.5)-7.5
Measuring Rim: 6.5"
Tread Depth:8.4
Overall Diameter: 635
Overall Width: 212
Overall Width on 5.5" rim: 202 (allowing ~5mm for each .5" change from the measuring rim size according to Tirerack and the Wheel and Tyre Bible)
Revs/mile: 831
Rolling Circumference (1609344/(Revs/mile)): 1937
Differences of 205/50R17 T1-R compared to 175/55R17 RE040:
Overall Diameter: +11mm (+1.8%)
Overall Width: +20mm (+11%)
Rolling Circumference: +34mm (+1.8%)
I realise that some people have had problems with 205/40R17 tyres fitted to standard rear wheels on the front, but the width of a 205/40R17 T1-R on a 7.5" rim is 219mm and with the increased offset of the wheel (+10mm), that would put the inner edge of the tyre (219-202)/2 + 10 = 18.5mm closer to the chassis rails (where I believe these tyres rub) than a 205/50R17.
The issues:
- Is the outside diameter too large? Would they rub on the wheelarch liners? Or would they foul the chassis rails on full lock?
- Many 205/50R17 tyres are reinforced (including the Toyo T1-R and T1-S). Other posts indicate that this is undesirable on a car as light as a VX220. Tyres are available that are not reinforced, but it appears that the Toyos are a couple of millimetres smaller (in width and diameter) than most tyres of this size. The Yokohama AVS Sport also appears to be a fraction smaller than average and is not reinforced.
- Is it wise to use a tyre at the limit of its recommended rim width range?
- Are they close enough to standard size for the ABS to still function? (They are closer in size to the rear tyres than the standard fronts).
- Will they give a reasonable balance with the rear tyres? Old 911s had a much greater rearward weight bias than a VX220 and still used 205s on the front and 225s on the rear.
