Front Clam Removal Guide
75 replies to this topic
#61 VXTyrant
VXTyrant
    Red Rules!
  • 2,198 posts
Posted 31 March 2011 - 02:06 PM
Right I've just found the PDF version of this that someone did a coule of years ago with all the pics still intact
Sorry for the thread revival but has anyone got a PDF version of this guide with the images intact as they no longer seem to be in this PDF guide :unsure:
Yeah lad, punt me your email via PM and I'll send you the front and rear clam removal guides. All I need is your sisters phone number :P
Will you really take her off my hands :P
PM sent... regarding my email and the guides ;) got your hopes up there didn't I :happy:
Oh and cheers chinky chinky
#62 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 07 April 2011 - 10:11 AM
Front and rear clam removal guides in PDF format (with pictures!) from WIKI site
wikisite Front and rear Clam Removal Guides
#63 Dashwood
Dashwood
  • 494 posts
  • Interests:discussion
Posted 02 June 2011 - 07:30 PM
Did mine and didn't even take the wheels off or raise it up. If the main bolts around the door jams are easy to do if you know everything will be okay. Just don't try undoing stuff all the way. Undo it a bit and then screw it back in to clear all the dust, crap and rust that has accumulated. Slowly slowly catchy monkey. My main problem was the wheelarch liner captive nut things, not rivnuts or rawl but something else. Just trying to undo them destoyed them and but wobbling them out after meant replacement was easy with brass rawl nuts.
#64 TazN
TazN
  • 2,931 posts
Posted 29 December 2012 - 02:40 PM
Been tackling this job today. Fogs are disconnected. Found out why at least the o/s was not working, rear cap was not connected and just left hanging! However the fun and games have started with the array of bolts/allen bits that are holding the clam in place. They seem to be a mixture of sizes and types (opposed to the original fixings) which look nice and new and the original fixings that are nearly falling apart from rusting. I'm having trouble however with the first bolt in the guide (step 6/7) I have removed the headlamps but for the life of me cant see a bolt except one that looks like it is holding the fog bracket to the clam. Is this the right bolt or am I looking in the wrong spot?
#65 nicollow
nicollow
  • 3,801 posts
Posted 29 December 2012 - 06:55 PM
Its right down at the bottom joint between the radiator cover and the clam. The bolt points directly outwards, in a horizontal direction. The best way to see it is to take the wheel arch liners out and stick your head in the wheel arch and look forward, you should see the wee buggers at the bottom ;)
#66 JG
JG
  • 13,612 posts
Posted 29 December 2012 - 07:05 PM
I think the best way is though the light. need to twist your arm to get to the 13mm bolts.
#67 TazN
TazN
  • 2,931 posts
Posted 30 December 2012 - 03:10 PM
Well still cant see them. I will jack it back up and get the wheel off and have a look. I wouldn't be surprised if they are MIA to be honest. I have now taken all bar 3 bolts out. 1 is in the recess where the headlight sits and has a god awful screw rather than a bolt, will be cutting that off. However the other 2 are a little more problematic. Both are on the n/s door section. The one at the bottom into the sill has completely rounded off but at least I have access to it for the dremel. The other is the one at the top of the door just under the top of the front clam. That has rounded itself off and being in the position it is I cant see how I can get at it to cut the head off. Any suggestions, particularly on this last bolt?
#68 vocky
Posted 30 December 2012 - 04:02 PM
take the door off for better access and then drill it out
#69 TazN
TazN
  • 2,931 posts
Posted 30 December 2012 - 04:46 PM
:/ was really hoping that wouldn't be the case.
#70 kevster
kevster
  • 73 posts
Posted 21 February 2015 - 08:30 AM
Front and rear clam removal guides in PDF format (with pictures!) from WIKI site wikisite Front and rear Clam Removal Guides
Hi all, Could anyone point me towards another source to this guide with pictures? The wiki link seems have expired and the pictures won't load from the original description. Many thanks for any help. Kev
#71 vocky
Posted 21 February 2015 - 08:56 AM
http://www.speedster...hing Points.pdf
http://www.speedster...and Install.pdf
#72 kevster
kevster
  • 73 posts
Posted 21 February 2015 - 09:39 PM
http://www.speedster...hing Points.pdf   http://www.speedster...and Install.pdf   http://www.speedster...and Install.pdf   http://www.speedster...and Install.pdf
Brilliant...thanks vocky
#73 M9ABR
M9ABR
  • 6 posts
Posted 24 March 2017 - 08:04 AM
The bolt on top of drivers side cill has came out after drilling but nut cert retainer seems to have fallen into cill, anyone had this before?? New radiator fitted and I'm dying to get it out this weekend for my first drive in it. Urgent! Lol
#74 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 13 June 2018 - 05:07 PM
Can you remove the front clam without removing the front lid?
Br, Per
#75 siztenboots
Posted 14 June 2018 - 08:37 AM
the front lid bracket is bolted to the rad surround , not the clam itself
#76 vocky
Posted 14 June 2018 - 07:37 PM
you can remove the front clam and leave the front bonnet in place, but it's not worth the extra hassle
