Charge Cooler Coolant
Posted 15 March 2006 - 03:00 AM
Posted 15 March 2006 - 07:30 AM
Posted 15 March 2006 - 09:46 AM
Posted 15 March 2006 - 10:00 AM
Are you going to paost a "How to" thread on how you installed your charge cooler?Looks like i had a small leak from one of the pipes on my charge cooler. Sorted now though.
Posted 15 March 2006 - 01:05 PM
clicky.
This is good for -25 Deg C, however the more percentage water the higher the heat transfer co-efficient of the fluid, for the malasian market we speced 70/30. So if the car is not going to to see very cold condition then you could increase to this to get a bit more cooling.
Rob
Posted 15 March 2006 - 09:00 PM
Posted 15 March 2006 - 09:56 PM
Why? they're all just Eythel-Glycol based, with different addatives to inhibit corrosion.if you are adding more coolant mixture make usre you add the same stuff thats in there already
That was the summry of a very boaring 3 hour meet i had with Valvoline.
Posted 15 March 2006 - 10:08 PM
I would if I had fitted it. AmD in Bicester did it.Are you going to paost a "How to" thread on how you installed your charge cooler?
Guess I should get some de-ionised water after all. Many thanks.
Posted 16 March 2006 - 03:47 AM
Posted 16 March 2006 - 12:57 PM
Posted 16 March 2006 - 01:49 PM
