Fitted Braided Hoses!
15 replies to this topic
#1 djegiant
djegiant
  • 2,367 posts
Posted 15 March 2006 - 05:35 PM
Fitted my goodridge hoses today! :) Flushed a total of 1.5L of castrol dot 4 through it and im certain that there is no air in it! thumbsup Brakes do feel pretty spongy with a slightly lower pressure point that before! :( Surely this aint right! :unsure: Also ABS seems to kick in earlier! :blink: Anyone have any ideas! :drink:
#2 chris
chris
  • 524 posts
Posted 15 March 2006 - 06:35 PM
Air in ABS control block ... :(
#3 djegiant
djegiant
  • 2,367 posts
Posted 15 March 2006 - 06:42 PM
Bugger! :( Anyone know the solution???? :unsure:
#4 djegiant
djegiant
  • 2,367 posts
Posted 15 March 2006 - 07:05 PM
:tumble:
#5 Whiteboy
Whiteboy
  • 6,950 posts
Posted 15 March 2006 - 07:08 PM
I believe you need the ignition on and then pump the brakes to clear the abs unit.
#6 robsrocket
robsrocket
  • 597 posts
Posted 15 March 2006 - 08:54 PM
My mate did this to his S1 Exige and was not happy with the end result at all. If i remeber right he had to take the calipers off and turn them upside down or something like that. If you need more help i can get more details of him for you. Robs Rocket
#7 PaulCP
PaulCP
  • 6,064 posts
Posted 15 March 2006 - 09:08 PM
Robs Rocket
That's exactly what the problem is but i'm sure that djegiant has already found that out from the search facility ;)
You need to take the calipers off and turn them through 360 degrees whilst bleeding them
#8 MAP18W
MAP18W
  • 348 posts
Posted 16 March 2006 - 01:30 PM
If you have air in the ABS module there is a procedure on Tech2 to allow you to activate the ABS whilst bleeding the brakes.
#9 djegiant
djegiant
  • 2,367 posts
Posted 16 March 2006 - 03:52 PM
Is this a Vauxhall type thing then???? Im in N Wales! :(
#10 MAP18W
MAP18W
  • 348 posts
Posted 16 March 2006 - 03:55 PM
Im in N Wales! :(
Tech2 - Vauxhall Diagnostic Equipment. Any dealer or Vauxhall Specialist.
#11 csl_freak
csl_freak
  • 98 posts
Posted 16 March 2006 - 09:18 PM
Tech2 is the way to go, turning the calipers is an s1 issue only (doesnt apply to s2 or opel/vx). Otherwise quick and dirty solution is to drive the car over a surface (gravel/earth) that makes the abs work, do that a few times, then purge again, and do this until problem solved. Which it will be, eventually..could take just one extra bleed, or 3 or 4... Good luck
#12 PaulCP
PaulCP
  • 6,064 posts
Posted 16 March 2006 - 09:28 PM
OK then i'll have to accept that i don't know what i'm talking about
Even after having the same problem and resolving it by turning the calipers :o Oh and following the instructions for fitting braided hoses to an S2. ;)
Sorry for wasting your time. Looks like the Lotus guys don't have a clue either since they all invert their calipers whilst bleeding after fitting braide hoses to S2's.
#13 Arno
Arno
  • 1,237 posts
Posted 17 March 2006 - 06:48 AM
Huh? Come again?
The caliphers are exactly the same on the S1, S2 and VX. And the fronts ones still do NOT have a separate bleed nipple on the inner piston to allow air trapped in it to be bled out.
The only link between the two pistons is through the pipe at the bottom of the calipher and as bubbles rise to the top you'll never get all the air out unless you do the bleed-invert-bleed-upright-bleed sequence.
For just flushing brake fluid this is not an issue as you don't introduce air into the system, but when fitting new brake lines this does need to be done.
#14 Thorney
Thorney
  • 11,404 posts
    Fluffy bunny rabbits.
Posted 17 March 2006 - 07:06 AM
Correct, invert the caliper when bleeding thumbsup The Tech 2 function is the easiest way (but most people don't have access to £4k worth of computer equipment ;) ) but in all honesty we tend to do the invert trick as we cba to plug the Tech2 in :D
#15 djegiant
djegiant
  • 2,367 posts
Posted 17 March 2006 - 04:31 PM
What a poor caliper design! thumbsdown Thanks for the advice guys! thumbsup Used my own little take on that idea in the end and while someone was holding pressure on the pedal I cracked off the unions into the calipers a small amount! Sure enough a small hiss followed by a bit of fluid leakage! thumbsup Brakes feel much better now! :) This method gets rid of all air trapped in the inside chamber! Woo hoo! :) Thanks again! thumbsup
#16 christurbo
christurbo
  • 3,784 posts
  • Interests:My Civic Type R
    My Black Beast of a VX!!!
Posted 17 March 2006 - 04:38 PM
Good thread - stuck into the 'useful thread sticky'
>Here<
