Ant, at what temperature do i really have to add a bit of petrol?
Coldest these past few days as been ITRO 12 degrees C.
depends how much you like having to turn it over endlessly.... i'll probably be chucking in some petrol when it gets to 12 degrees, it sometimes helps to start with a bit of dinodiesel and then move onto petrol when it gets really cold.
chuffing clutch has begun to stick again, so i wound it out a bit on the cable. there was corrosion everywhere from where the battery leaked the other week... i don't know if that has made it worse, my only consolation being that at least the battery acid can't eat through any of the clutch mechanism, but it does look like it'll need changing soon... James? help please? you have done one before after all
