Sheds-r-us
1051 replies to this topic
#921 Guest_AntB (Guest)
Guest_AntB (Guest)
Posted 29 July 2008 - 04:30 PM
I'll get more for you if you like but they are about 17 quid each these days :(
i'll work out how many i'm likely to need thumbsup
#922 cheeky_chops
cheeky_chops
  • 7,922 posts
Posted 02 August 2008 - 12:32 PM
WOHOO! Shed passes MOT again :groupjump: Got quite a list of advisories though :rolleyes:
#923 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 02 August 2008 - 04:56 PM
I'm selling my VXT soon, and will be getting a shed. Although I will no longer own a VX220, would I still be allowed to post in this thread? :rolleyes:
#924 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 03 August 2008 - 12:08 AM
chinky chinky ill give you my shed lol
#925 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 03 August 2008 - 01:18 PM
:lol: cheer Fab. Does it have wheels and an engine? edit: loving your new sig!
Edited by p4cks, 03 August 2008 - 01:19 PM.
#926 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 03 August 2008 - 01:21 PM
of couse its a porsche :P
#927 cheeky_chops
cheeky_chops
  • 7,922 posts
Posted 05 August 2008 - 08:05 PM
Spoke to soon Back of the car looks like it has been thru a hairdressers and caught a wig!!! I guess its the contents of the backbox disintegrating :rolleyes:
#928 Victor Xray
Victor Xray
  • 608 posts
Posted 06 August 2008 - 09:51 AM
Where do most people get tyres for their Shed's? I need a new one (maybe 2) for the Astra.....
#929 Tfp
Tfp
  • 1,514 posts
Posted 06 August 2008 - 11:07 AM
Huntingdon Performance tyres in Godmanchester are about the cheapest in our area, ring for a quote before you go.
Tim.
#930 AntonG
AntonG
  • 258 posts
Posted 06 August 2008 - 11:19 AM
Just realised the new shed has done 5k miles since the 2th of may!! (the vx has done 5k miles in 24months :lol:)
Not quite as cheap to service as the corsa either. cambelt on the corsa was £17 :D
the kit for the volvo is £120 includes two belts, three tentioners and a stretch bolt for the crank pulley.
I've a feeling the procedure could be be fairly exciting :rolleyes:
JG you've got an audi engine in your shed at a guess - it's not too bad a job to do. I've got an old audi with the same engine and recently done the belts. A word of warning is be very careful about pump timing they through a hissy fit if it's not right.
On a seperate one my derv fuel economy has been falling right off recently, used to do 45ish now down to 35ish, it's have new tires that are slightly wider than the old ones but i wouldn't expect it to make that much difference. Anyone got any other suggestions - already clean intercooler, inlet manifold, blanked of egr and changed air filter.... Also noticed it seems quite smokey (black soot)
#931 Joss
Joss
  • 1,892 posts
  • Interests:everything
Posted 06 August 2008 - 11:38 AM
I have the same problem on my citroen - after replacing the cat it was good for a while but has started smoking gradually more again - is your cat blocking up? a citroen forum bod has suggested EGR valve, worth a try I guess - now to find where it is and where I can get one, what does blanking it achieve?
#932 Victor Xray
Victor Xray
  • 608 posts
Posted 06 August 2008 - 01:46 PM
Tim.
Thanks for the tip mate chinky chinky I'll give them a call!
Simon
#933 Pedro
Pedro
  • 404 posts
Posted 06 August 2008 - 02:49 PM
Another shed update.. My merc just had it's 195,000 mile service, treated it to new plugs, fluids and pads all round, plus a tyre as the tracking is a bit out. Also had to get a rear spring for it as the original one had given up the ghost - that cost £22.50 plus roland rat. Runs like a dream now, getting roughly about 10 miles to the litre thumbsup The dashboard appears to be having a stroke though, bits have stopped working on the left hand side - intermittent wipe, bulbs and the outside temp gauge.
#934 EdButler
EdButler
  • 731 posts
Posted 06 August 2008 - 02:58 PM
This simply means (as you may know already) that it is running too rich. You've already done most of the things to check, but it could bad fuel economy could certainly be a blocked CAT. Diesels can pass an MOT without a cat anyway (its all done on particulate emissions) so you could try that?
You could possibly have a boost leak between the turbo and inlet manifold. Its usually best to listen out for a hissing noise whilst driving or revving the engine.
Also check tyre pressures ofcourse.
My old TDi Ibiza ran like a different car on some fuel types - stay clear of supermarket crap as you dont usually know where its come from. Stay to high volume decent branded fuel stations.
#935 JG
JG
  • 13,612 posts
Posted 11 August 2008 - 10:48 AM
Hi Anton,
I do indeed have the Audi engine. i've just done the cam belts and it wasn't too hard. The only really slight pain is the stretch bolt for the crank pulley. 220Nm + 180 degrees nearly killed me.
The pump is much easier on the volvo as the engine is transverse so access is very good. trying to get to the back of the Audi for the pump is a right PITA.
Its all going well, i'm not so scared aboyut putting my foot down now with the new belts and pulleys, so i'm not getting 50mpg either. Although i think i am getting in the low to mid 40s.
#936 Guest_AntB (Guest)
Guest_AntB (Guest)
Posted 13 August 2008 - 07:56 AM
the shed is making a most godawful noise under acceleration above 70mph at the moment (this is on a private road obviously) it seems to literally only happen under acceleration, but is coming from the nearside front of the car, where there actually isn't any engine. one would assume that if it were a cv joint/ or wheel bearing, for example, the noise would be constant...? nearside front tyre has a random gouge out of it as well, eep, expense!
#937 JG
JG
  • 13,612 posts
Posted 26 September 2008 - 01:16 PM
Hows the volvo Ant? :D
#938 Guest_AntB (Guest)
Guest_AntB (Guest)
Posted 26 September 2008 - 01:42 PM
volvo is good, service light is still on tho James, did you find out anything about that? ;) :poke: i'm currently organising my production of biodiesel and i have heard some good reports of that garage near you that sells bio James, which i'll happily relay to you via email/ pm if you want to drop me a line? i have to say that the volvo is the most soul- destroyingly bland/ bad car to drive though! if the vx ever gets sold (to a newb happy to buy a properly looked after car instead of a cheap one that they then have to post endless questions about how to fix :rolleyes: ) i think i'll have to buy a 205GTi or something as a toy, i hate being this detached from proper driving :(
#939 JG
JG
  • 13,612 posts
Posted 26 September 2008 - 01:45 PM
Hehe, I know what you mean. Perfect complement to a VX or a Gti though. Still unsure of bio-ing my volvo. Although would be interested to heat about the guy next door to me that sells it.
#940 JG
JG
  • 13,612 posts
Posted 26 September 2008 - 01:46 PM
oh and haven't found a fix for lights. and can't get OBD2 to work on mine :angry:
