JamesGray, on Jun 9 2006, 09:36 , said:
Does the noise stop if you put your foot on the clutch, Ant?
if i change into another gear, yes
why what do you think it might be?
Posted 09 June 2006 - 10:57 AM
Posted 09 June 2006 - 11:03 AM
Edited by JamesGray, 09 June 2006 - 11:04 AM.
Posted 09 June 2006 - 11:11 AM
JamesGray, on Jun 9 2006, 12:03 , said:
nothing wrong with it - if it makes a slight noise as you select each gear then the sycromeshes are all probably a bit worn. If it makes a contiuous noise the main shaft bearings have probably seen better days. If it makes a noise when you have you foot on the clutch it could the spigit (sp?) bearing (which picks up the clutch when it disengages with the engine)
None of these are a paticular worry and almost certainly wont let you down. So keep the car!
Edited by AntB, 09 June 2006 - 11:12 AM.
Posted 12 June 2006 - 08:24 AM
Edited by JamesGray, 12 June 2006 - 08:25 AM.
Posted 12 June 2006 - 10:40 AM
JamesGray, on Jun 12 2006, 09:24 , said:
Well the gearbox oil seals are done on the shed, no more leaking:
So far it has cost £6.80
Gets a bit warm at 80mph on the motorway in this weather, two solutions:
-cause is a slightly blocked radiator; replacement is about 50 quid
-drive with the heater on and the windows down and its perfect![]()
i'll sort it out properly eventually.
Posted 15 June 2006 - 10:07 PM
Posted 15 June 2006 - 11:03 PM
cheeky_chops, on Jun 15 2006, 23:07 , said:
60mpg
Fook me, i need to get a new shed!!!
My rover 214si is (touch wood) still going strongDone over 6000 miles in it since last Nov
Posted 16 June 2006 - 02:23 PM
AntB, on Jun 15 2006, 22:03 , said:
the shed was frowned at earlier. dropped to 50 odd mpg
Posted 16 June 2006 - 02:32 PM
have you tried mixing in any vege oil?? <a href="http://www.ravenfamily.org/andyg/vegoil.htm" target="_blank">http://www.ravenfamily.org/andyg/vegoil.htm </a>
£1.60 from tesco for 3 litres
Posted 16 June 2006 - 03:19 PM
Edited by cheeky_chops, 16 June 2006 - 03:20 PM.
Posted 16 June 2006 - 04:07 PM
Posted 18 June 2006 - 10:26 AM
Edited by AntB, 18 June 2006 - 10:29 AM.
Posted 20 June 2006 - 01:31 PM
Edited by JamesGray, 20 June 2006 - 01:32 PM.
Posted 22 June 2006 - 09:49 PM
Posted 23 June 2006 - 08:17 AM
Posted 23 June 2006 - 02:52 PM
AntB, on Jun 18 2006, 11:26 , said:
other than being a total skinflint the other reason that i want to do the biodiesel thing is so i can sound w@nky and 'reduce my carbon footprint'.
