Brake Servo Hose
35 replies to this topic
#21 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,844 posts
  • Interests:Big baps.
Posted 19 May 2013 - 09:10 PM
Thanks FLD, I'll be brave and have a go!
#22 FLD
Posted 19 May 2013 - 09:12 PM
I pulled it through from the engine bay to the access hole in the sill and then from the sill to the servo.  The sill to the servo is the hardest bit.  Good luck with it.  thumbsup
#23 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,844 posts
Posted 15 June 2013 - 10:22 AM
Well, finally got round to doing this job.
Bought one of these garden hose connectors, and it was such a tight fit I didn't bother using wire or anything. If I was doing it again I think I'd use some tape.
I was worried that the wide bits might catch, so I ground them off.
This is it, all connected up.
I unclipped the hose on the clip I could reach. Not sure this was a good idea. So far I haven't tried to put it back. I'll have a go after lunch.
Gave a big tug of my hose (ooh er missus) but it wouldn't budge. Was about to give up but gave it one last tug and it came through.
You do have to keep feeding it from the other end, so two people does save time, although I did it alone.
I then pulled it through from the front and it seemed to go easier. Right up until this happened.
:beat:
There was no way to push the new hose through from the passenger compartment so I pushed the old one back and reattached. I then added some washing up liquid. Something fell on the sill floor. Turned out to be the gromet.
This time all went well. I put the gromet back and attached the hose at both ends.
Just the usual VX maintenance damage.
So was it worth it?
I think this is the original, now 10 years old hose.
The brakes have always been crap. The previous owner said the brakes were crap, and he owned it from nearly new so I just assumed VX brakes were crap. It was only when briefly driving DaveMate's car last year that I realised it was my VX that had crap brakes.
Don't know what they're like now - have a few other jobs to do before a test drive, but I'm hoping I now have some servo assistance.
#24 kingwowns
kingwowns
  • 686 posts
Posted 16 June 2013 - 03:26 PM
Good pics-It'll be good if you can update on any improvement you feel when driving!
#25 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,844 posts
Posted 18 June 2013 - 07:53 PM
Seem a bit better, but still not great. Maybe I have a dodgy servo.
#26 kingwowns
kingwowns
  • 686 posts
Posted 18 June 2013 - 09:23 PM
Cheers kurt!
#27 sford
sford
  • 1,454 posts
Posted 31 July 2013 - 09:06 AM
So I'm doing this at the weekend and my question is this; the bit between the one way valve and the inlet manifold, is this anything special or is it just to accommodate the presence of the one way valve? Figured while I'm there I may as well replace it all if I can.
#28 vocky
Posted 31 July 2013 - 09:10 AM
it might be the same hose, sometimes it's slightly smaller hose, but you should replace it at the same time.
#29 deano01
deano01
  • 1,480 posts
  • Interests:Playing with chainsaws and other power tools, Films, rallying, fishing, Vx
Posted 31 July 2013 - 08:52 PM
:yeahthat:
Same size hose on mine and well worth replacing at the same time. Remember which way the valve goes ;)
#30 gumball3000
gumball3000
  • 109 posts
Posted 31 July 2013 - 09:47 PM
time for the stupid question , on a really good thread
my hose is split servo end
may I ask were the replacement hose was purchased   ( MAIN DEALER ??????? )
#31 FLD
Posted 01 August 2013 - 08:42 AM
vacuum rated hose from cbsonline is the cheapest option.
#32 Tony H
Tony H
    Lotus on Crack
  • 1,729 posts
Posted 01 August 2013 - 08:47 AM
It was 24.27+vat autovaux in April part number 93188760.
You should get the one FLD says I reckon.
I need to replace mine. The bit going into the sill looks fine, is it acceptable to just replace the damaged end sections and join to the old pipe?
#33 Crimson_Killa
Crimson_Killa
    Posting My Opinion
  • 2,962 posts
Posted 01 June 2015 - 03:50 PM
time to resurrect.
i'm very sure this is whats wrong with my brakes.
the pare from Autovax is now £42 inc VAT so a no thanks from me. what do i need to get from [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]cbsonline?[/color]
#34 KurtVerbose
KurtVerbose
    His Serene Highness
  • 3,844 posts
Posted 21 June 2015 - 05:42 PM
My hose was in shocking condition and definitely needed replacing, but it was actually still maintaining vacuum. I tried driving with the hose disconnected just to see if it made a difference - and it did, big time!
#35 entwistlea
entwistlea
  • 5 posts
Posted 17 March 2018 - 11:44 AM
Resurrecting this if you don't mind, my brakes are shot, one good pump of the pedal and then I have no more, so either a failed servo or the hose ( which would be nice).
These are great step by steps to do the job, but ahead of me tackling anyone got any pics or explain where the hose attaches in the engine bay, is it simple to get to ?
Cheers all
#36 Nev
Posted 17 March 2018 - 11:56 AM
Also check the 1-way valve which is near the inlet manifold, if that fails (particularly on a turbo car) it will cause similar symptoms.
