Upgrading The Diverter Valve
6 replies to this topic
#1 kmpowell
kmpowell
  • 81 posts
Posted 14 May 2006 - 11:58 AM
If I am right, the 2.0 VXT engine (Z20LET I think?) has a recirculating diverter valve, and a similar setup to the 1.8T Audi engine e.g MAF etc. It's commonly known that you can upgrade the standard Audi Diverter Valve with a faster moving piston-type valve (normally from Forge Motorsport or AmD), which improves throttle response and gives a smoother delivery of power. I've seen a few Dump(blow off) Valves availble for the VX, but if the VX lump is like the Audi lump, it will not respond well to them and will just end up knackering the MAF. So... is there a replacement Diverter Valve for the VX that is trusted and proved? Or is the VX DV good enough that it doesn't need to be upgraded? TIA :) Kevin
Edited by kmpowell, 14 May 2006 - 12:46 PM.
#2 Joe-Turbo
Joe-Turbo
  • 4,176 posts
Posted 14 May 2006 - 12:26 PM
im affraid i dont know the answer to your question but i have read a few peoples posts that have installed a baileys DV that have taken them off again because performance decreased. have a search dont even know what a Diverter Valve is so hopefully someone else can answer that. thumbsup
#3 kmpowell
kmpowell
  • 81 posts
Posted 14 May 2006 - 12:55 PM
thumbsup
Hi Joe
DV's come in two flavours. The Recirculation type (known as a Diverter Valve) are fitted to cars that use an Mass AirFlow meter (MAF sensor) such as the VXT and Audi 1.8T cars. Then there are Atmospheric types (known as a Dump Valve or Blow Off Valve) which dump all their air into the atmosphere (that woooosh noise). The Dump/Blow off valve is not closed loop so the ECU loses track of whats going on, and that's what causes the problems on MAF equipped cars. Baily DV's are normally 'Dump' valves, so that is why they had problems/performance issues if they fitted one to a VXT.
Diverter valves recirculate the air which keeps things constant and easily monitored. The thing with OEM Diverter valves is they are not normally very quick, so to replace it with a faster moving piston Diverter Valve, will not only improve throttle response, but will also give a smother delivery of power. :)
Cheers
Kevin
#4 Thorney
Thorney
  • 11,404 posts
    Fluffy bunny rabbits.
Posted 14 May 2006 - 04:55 PM
We have internal re-circ vales that are integral to the turbo. DOnt mess, no point.
#5 kmpowell
kmpowell
  • 81 posts
Posted 14 May 2006 - 05:02 PM
Thanks John. I thought that might be the case 'cos i've not seen any of the tuners offering it. thumbsup
p.s Hopefully pick up the VXT next Sat! :groupjump:
#6 urbanmac
urbanmac
  • 951 posts
Posted 14 May 2006 - 05:53 PM
so you bought one!
thumbsup
#7 kmpowell
kmpowell
  • 81 posts
Posted 14 May 2006 - 06:04 PM
so you bought one!
thumbsup
Subject to being accepted for the finance, yes! :D
