Engine Ticking Noise
Posted 21 June 2006 - 08:35 AM
Posted 21 June 2006 - 09:43 AM
Edited by JamesGray, 21 June 2006 - 01:18 PM.
Posted 21 June 2006 - 10:14 AM
stop driving
Flat bed to speacialist or tursted dealer.
your kidding right?
Posted 21 June 2006 - 10:28 AM
Posted 21 June 2006 - 10:29 AM
Posted 21 June 2006 - 11:52 AM
It the 2.0 turbo engine, it has an in built fault. The accessory pulley is 3mm out of line and leads to wear of the belt.. It starts with ticking (as explained above) and can in the worst possible case end up with it lunching the cam belt and the pistons having an unscheduled meeting with the valves: Meaning very very big bill to fix and you without your VX for a long time in thislovley weather.
Don’t drive it.. Ring the AA and get it to somewhere to get it fixed. If its out of warranty I would push for Vauxhall to pay for it as there is a known fix for it: I think it’s a new pulley bracket.
http://www.vx220.org...s...c=31103&hl=
there a a few more if you search for "ticking"
Edited by P444UL_R, 21 June 2006 - 12:01 PM.
Posted 21 June 2006 - 01:21 PM
stop driving
your kidding right?
Nope
for the reasons detailled above. Any ticking from engine (that matches engine frequency) means that something isn't right. The fact that there are known problems with the alternator belt shedding and taking the timming belt with it, is a fairly good indication that you should not drive it.
Posted 21 June 2006 - 02:05 PM
stop driving
Flat bed to speacialist or trusted dealer.
Nice and subtle as usual James
Posted 21 June 2006 - 03:54 PM
Posted 21 June 2006 - 04:30 PM
Posted 21 June 2006 - 04:41 PM
As far as I know a broken cambelt could lunch the engine, not an alternator belt??
You're right, but on the VX, when the alternator belt breaks it has a nasty habit of taking out the cambelt at the same time, hence the warning.
Posted 21 June 2006 - 04:44 PM
Posted 21 June 2006 - 04:48 PM
Posted 21 June 2006 - 04:51 PM
stop driving
Seriously though. Described as 'rattling like GTA' means its probably pretty bloody loud. Heard of a few vxts blow their engines now. Why take the risk?
Posted 26 June 2006 - 01:53 PM
