did you nat fancy makng the tips larger to fill the holes?
Loving the welds
are you going to wrap it?
The tips are actually quite large (same outer diametre as original if not a bit larger) it looks a bit strange in the pic though... (The inner diametre is much bigger, since the walls are quite thin) But they are a bit closer together...
The bottom one is fake
and I have actually lost it now...
I did a bit of bad welding...
Well I'm planning to make new tips before spring, probably a letterbox one like Regal.
Well the, nice welds are made by Dude, I made the crappy ones...
No, I'm not going to wrap it. I thought about it and would have done it if it got to hot in the engine bay, but so far no problem with that.
The only good reason for wrapping an exhaust system on an NA-engine is if you have problem with radiating heat from the system.
If that is not a problem it is actually good if the exhaustsystem gives away much heat, that means that the exhaust gasses cool down, which means that the gas volume goes down, this means lower back pressure and easier flow thru the system because there is less gas volume to pass (no pun intended
Wrapping the system isolates the gasses and they keep higher temperature and volume, this is only good on a turbo system (before the turbo) because there you want high pressure to keep the turbo spinning as quick as possible.
But as I said, sometimes you need to wrap the system because the radiating heat causes problem somewere else... But I haven't had any problems with that yet anyway. I did make a heatshield between the manifold and the boot.
