V Important - New Recalls
430 replies to this topic
#101 SteveM
SteveM
  • 1,608 posts
Posted 26 July 2006 - 06:19 PM
Mine's booked in for both - from what I could see looking over the guy's shoulder, the brake hose recall affects all build numbers up to something in the 7000 range, and the wheel recall affects all build numbers up to something in the high 3000 range (39xx I think).
Interesting, looks like I might just miss out on the wheels as mine is the 4000s. Will check my wheels for the HT mark tomorrow as they're taking up space in my dad's garage at the moment :P
#102 mcbunny
mcbunny
  • 533 posts
Posted 26 July 2006 - 06:26 PM
my na wheels that seem to be affected for all your info
#103 JG
JG
  • 13,612 posts
Posted 26 July 2006 - 07:20 PM
Mine are H.T :groupjump:
#104 CocoPops
CocoPops
  • 17,181 posts
Posted 26 July 2006 - 07:25 PM
Mine aren't :P
#105 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 26 July 2006 - 07:39 PM
HERE is the original discussion, which shows this photograph:
:o
#106 leebo
leebo
  • 48 posts
Posted 26 July 2006 - 08:05 PM
oh Sh!te :angry: mine need replacing, i have an ly so this means silver wheels for me then???
#107 CocoPops
CocoPops
  • 17,181 posts
Posted 26 July 2006 - 08:17 PM
I've got a case open with Vaux customer service.
The best outcome is that they replace the rears, then pay to have ALL four wheels powder coated so that they match.
I shall keep you updated as soon as I hear.
#108 Mick43
Mick43
  • 3,305 posts
  • Interests:Cars, Bikes, Sport (tennis, squash, gym)
Posted 26 July 2006 - 08:32 PM
re: servo pipe - good news that VX are aware of problem and will replace FOC... I hope their supplier is using something stronger this time :beat: .... or I will supply some proper pipe for dealer to fit !! (for those that don't already know, it may just look split at the end.. but the inner wall has probably collapsed most of it's entire length, especially on bends... hence very dangerous.... and hence no doubt the formal recall....)
#109 CocoPops
CocoPops
  • 17,181 posts
Posted 26 July 2006 - 08:39 PM
Note... I was told by customer services that.... The wheels are a RECALL..... the pipe is a REWORK.... apparently the pipe is less serious than the wheels..... go figure.
#110 snoopstah
snoopstah
  • 3,056 posts
Posted 26 July 2006 - 08:43 PM
The pipe is arguably less dangerous - even if it completely disintegrates or falls off, you still have non-servo-assisted braking, so it's not like you lost all ability the brake the car. The most dangerous bit really is if the pedal starts off hard and then the pipe starts vacuuming properly again, causing the brakes to suddenly apply sharply. However, if the wheel disintegrates, you are going to crash. With the older NAs, there's a good chance the car would be written off, and as with any crash, there's danger to the occupants as well...
#111 luna_s
luna_s
  • 1,934 posts
Posted 26 July 2006 - 08:48 PM
no mention of hub carrier bolts... ? i agree with the servo hose, theoretically it could cause rough running if the hose is leaking at the engine side (Did on previous cars i owned), guess we will have to wait to see if they replace the full length, tbh i think id rather replace the hose myself....
#112 convict
convict
  • 1,508 posts
Posted 26 July 2006 - 08:50 PM
As I understand Thorney's thread, the intention isn't to replace the hose, just either end, which seems to defeat the point entirely.
After re-reading the original thread on the wheels from speedyk, it would appear that in Switz, the whole hose has been replaced (4 hour job), rather than a quick bodge job.
#113 leebo
leebo
  • 48 posts
Posted 26 July 2006 - 08:54 PM
cheers cocopops thumbsup
#114 christurbo
christurbo
  • 3,784 posts
  • Interests:My Civic Type R
    My Black Beast of a VX!!!
Posted 26 July 2006 - 09:00 PM
My hose looks OK ... but im still having the rework done.
#115 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 26 July 2006 - 09:08 PM
I would suggest you re-read Johns post then....it's as clear as day that the whole pipe will be replaced....
#116 Anarchy
Anarchy
  • 2,237 posts
Posted 26 July 2006 - 09:24 PM
My hose looks knackered near the engine, prob due to heat and bending and where it is froced over the cylinder thing in the front. Inside the sill is a long straight run with no heat, so maybe OK. Like someone said nice shiny new back wheels :D $hitty old fronts poof how much does anyone reckon it would be to have fronts resprayed? Are this style of wheel available in 16" which everyone seems raves about?
#117 jules_s
jules_s
  • 15,275 posts
Posted 26 July 2006 - 09:31 PM
If mine need replacing (I dont think they will, fingers crossed) I will be insisting on a set of LY wheels and my fronts done to match. Given how long vaux have known about this problem.... and they allowed us to happily drive around with dangerous wheels, its the least they can do :rolleyes:
#118 convict
convict
  • 1,508 posts
Posted 26 July 2006 - 09:48 PM
Personally, I don't think its as clear as day light from this:
BRAKE SERVO HOSE
This is not considered a safety recall but is still important to get it done. We all know of the issue but now Vauxhall have decided to officially sort it, its basically where the servo hose splits at the end, Vauxhall have deiced to replace
Nor given that you've already said that Vaux have only replaced the ends of yours and JamesGrey's hoses when they know there's a recall imminent (they appear to have known in Switz for some months), does it suggest that vauxhall are going to replace the whole pipe when they've only quoted a job time of 90 minutes.
I apologise if I've jumped to wild conclusions there, but I think GM may take more than a small hit if they have to fork out for 4hrs labour plus parts for the 3000 odd vx/speedsters affected. I just naturally assumed that like any major company they will try getting out of anything if possible
#119 ajvx
ajvx
  • 49 posts
Posted 26 July 2006 - 10:02 PM
:flame: me if i missed this !! But why are all four wheels not affected? are the front different in some way? Andy
#120 CocoPops
CocoPops
  • 17,181 posts
Posted 26 July 2006 - 10:06 PM
There are no LY wheels mate :(
Thats the issue I've got........
