Heater Unit
29 replies to this topic
#21 walshy123
walshy123
  • 46 posts
Posted 17 January 2009 - 07:27 PM
Resistors will be far to powerful you need resistance wire, zirconium is the way to go. 2ohms for speed 1 and half that for speed two (i would imagine)
edit - FYI resistance is measured in ohms not watts.
thanks mate, im aware that resistance is measure in ohms, power rating is measure in watts. resistors have two main parameters - resistance and power rating. it was already stated that the resistance required is 1ohm and 2ohm, so i was asking what power rating i needed
why do you think a resistor would be too powerful? why would a 1ohm 300w resistor not suffice?
I'm going to use some 300-500W ceramic (or better yet Transistor packaged ones) resistors when I revamp the heater setup.
Good enough for an MGF, good enough for a plastic skip!
As you say 20*12 = 240Watts.... on full tilt, so with the resistors limiting the voltage (lets pretend the motor has a 1Ohm resistance too) by half and to 1/3rd you should be fine
any links to these?
#22 slindborg
Posted 17 January 2009 - 07:30 PM
www.google.co.uk
#23 182ian
182ian
  • 426 posts
Posted 17 January 2009 - 09:45 PM
Sounds like you have had good fun today! i have wondered recently why my no 1 fan speed is so quite. Probably not working then. haha. 2 and 3 are fine. We fit aircon sytems in the old cars at work. I wonder how the sizes of the units compare. hmmm
#24 rabidh
rabidh
  • 1,640 posts
Posted 21 January 2009 - 01:46 PM
My previous resistance wire bodge died, and I've now used 10W resistors from maplin. I used 1 ohm and 2 ohm, but decided to increase the power handling by using 2x2 Ohm in parallel, and 2x4 Ohm in parallel. I araldited them to an aluminium heatsink, as they did get quite hot after a while and I honestly think they wouldn't take it if they were on their own.
To be totally honest I think speed setting 1 (2 Ohm) is now a bit too slow, so I'd be tempted to go for 1.5 Ohm and 0.5 Ohm - or maybe 1 Ohm and 0.5 Ohm.
I used these because I was in a hurry and wanted to pick them up from a shop:
http://www.maplin.co...x?ModuleNo=2181
But really if I were you i'd just save myself some trouble and buy a 100W OR47 (speed 2) and 1R5 (speed 1) from here and don't put them in parallel:
http://www.rapidonli...resistors/65217
and then screw them to a sheet of aluminium through their mount holes. It'll cost you £7, look sexy, and it'll never, ever die.
#25 james141
james141
    Whiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiine
  • 3,667 posts
Posted 21 January 2009 - 01:51 PM
I dont see what the rush is to fix this, does anyone actually use the heater/blower on any setting other than full as even then it is like an asthmatic flea ?
#26 rabidh
rabidh
  • 1,640 posts
Posted 21 January 2009 - 01:54 PM
I use it... Sometimes you've got to find that balance between feeling your legs and being able to hear yourself think :)
#27 james141
james141
  • 3,667 posts
Posted 21 January 2009 - 01:56 PM
Its not that loud on full especially compared to the roof off/radio/exhaust/k+N etc :)
#28 slindborg
Posted 21 January 2009 - 08:07 PM
TBH if its a mechanical part on the car I like to know it will work as "intended" even if its never used.... cosmetic stuff can FRO as far as im concerned lol.
#29 techieboy
Posted 21 January 2009 - 09:11 PM
Good to see you've mellowed with fatherhood. In the old days I'm sure you'd have never used an abbreviation. :D
#30 slindborg
Posted 22 January 2009 - 08:28 AM
Actually, you shouldnt need to heatsink the 100W resistors as they are rated at 50W@25deg C with no heat sink.... should be more than enough, esp if you can mount them in the air flow pre heater rad.
I know, its all good... I could even be nice to people now lol
