200 Cell Cat On A N/a
39 replies to this topic
#21 VXJON
VXJON
  • 2,595 posts
Posted 16 September 2006 - 11:14 PM
quick update just got home after picking my car up,
Exhausts on :D
Sounds fooking good :D
No rattles or movement :D
Looks great :D
The eml is still on but since the two guys worked to 11o'clock on a sat night sorting the other problems i am quite happy to leave it at that until it can get rebooked. It sounds exactly as i asked for, burbles when idling, pops and bangs on the overun then roars on full throttle. Sounds quite similar to a piper box maybe a bit deeper tone
The old precat
How it looks now
Edited by VXJON, 16 September 2006 - 11:18 PM.
#22 LazyDonkey
LazyDonkey
    Lotus imposter
  • 7,748 posts
Posted 17 September 2006 - 03:04 PM
It sounds exactly as i asked for, burbles when idling, pops and bangs on the overun then roars on full throttle. Sounds nowhere near as nice as a piper box but i'm tight so i can't grumble.
thumbsup
#23 RWinstanley
RWinstanley
  • 482 posts
Posted 18 September 2006 - 11:55 AM
I was a non believer regarding sports cats :beat:
Having fitted a magnaflow 200 cell, I now recommend them :D
The magnaflow requires welding in place, but for less than £100 for the cat, worth the hassle thumbsup
Which one did you use? I've found this link to their product range, clicky
edit: found a better link. clicky
Edited by RWinstanley, 18 September 2006 - 11:59 AM.
#24 vocky
Posted 20 September 2006 - 07:53 AM
I used one of their stainless cat's, but the 91000 range is fine thumbsup
Edited by vocky, 20 September 2006 - 07:54 AM.
#25 RWinstanley
RWinstanley
  • 482 posts
Posted 20 September 2006 - 12:13 PM
Do you mean the 'Magnaflow Street/Racer Catalytic Converters' on the second link i posted? As these look from the pictures to be the best designs of diffusers i've from a fluid dynamic point of view. I don't know about the substrate, but these not generally much in it as long as it's 200 cell.
I've been thinking of options for replacing my cat section so may give this a go, i know a bit about emissions solutions ;)
Rob
#26 luna_s
luna_s
  • 1,934 posts
Posted 20 September 2006 - 02:49 PM
i got one from ebay, RM-Catalysts not fitted it yet, and mine was cheaper (their prices have gone up since i got mine) going to fit it soonish (another one of those jobs!)
#27 iceman
iceman
  • 18,159 posts
Posted 20 September 2006 - 04:29 PM
thumbsup
...but then one has to remember that NOTHING! sounds as good as the VSE (even more so, sans pre-cat and with sports cat) thumbsup
Nearest = B)
VSE = B) + :tt: + Imnotworthy
Edited by iceman, 20 September 2006 - 04:32 PM.
#28 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 26 September 2006 - 08:03 AM
have you put it on yet?
I think I might fit one myself any idea what size pipe it is?
#29 luna_s
luna_s
  • 1,934 posts
Posted 26 September 2006 - 05:13 PM
still not got round to it yet, busy with other stuff at the mo, plus im having fun and games getting the precat out! old cats all cut up ready to weld - its 50mm external, which is the same diameter as the standard cat, hopefully the welding will be strong enough!
#30 NickB787
NickB787
  • 7,813 posts
Posted 27 September 2006 - 09:30 AM
With the cat replacement would you use a dual O2 sensor unit or cut and weld in place keeping the sensors which are there? I would have thought it was easier to get one with sensors already on it
Edited by NickB777, 27 September 2006 - 09:31 AM.
#31 RWinstanley
RWinstanley
  • 482 posts
Posted 27 September 2006 - 11:26 AM
the problem with getting one's with the o2 sensor built in is there is the chance of not getting a good flow signal if it's not in the right place, thus setting off the EML.
This problem is also compounded by the removal of the precat as flow through this smooths out the flow considerably.
#32 vocky
Posted 27 September 2006 - 02:54 PM
it is best to keep the original sensors in their original positions thumbsup the main problem is the flowrate is far greater with a sports cat, so the position of the cat sensor requires a bit of thought the end of the sensor needs to be near the outside of the pipe, rather than near the middle where flow is at it's highest in the usa they use spacers to move the sensor to the edge of the exhaust pipe apparently if the sensor is spaced outside the flow of the exhaust you can even run without the main cat and not get an eml :unsure:
Edited by vocky, 27 September 2006 - 02:57 PM.
#33 Thorney
Thorney
  • 11,404 posts
    Fluffy bunny rabbits.
Posted 27 September 2006 - 03:12 PM
Remember the lambdas dont come into play under WOT only under general load so you wont get a problem at WOT but you're running as chance of running it lean without the Os sensors.
#34 oakmere
oakmere
  • 2,143 posts
Posted 29 September 2006 - 10:09 AM
I am also in the process of sourcing a new sport cat. I have called magnaflow uk and the price for pt No. 54304 (mirror Finnish stainless ceramic performance cat) is £74.80 including vat and delivery. This cat is a 300 cell not 200 cell but shouldn't set off the engine light, this cat is almost identical in dimensions to the original cat. The spun stainless steel are 200 cell metallic cats but prices are around £100 more and extra fabrication would be needed to fit. The other option is the e-bay cat at £90.00 + vat this is a 200 cell metallic but with a steel body not stainless. Any recommendations? Vocky must be using the 300 cell cat if he payed less than £100.00. Cheers Oakmere
#35 VXJON
VXJON
  • 2,595 posts
Posted 29 September 2006 - 11:16 AM
It turns out that the cat fitted to mine is the magnaflow :blink: The sensors have been welded into the orginal position and will definitely set of the eml :huh: I am going to try fixing a spacer but if this doesnt help i have a o2 sim on order
#36 rabidh
rabidh
  • 1,640 posts
Posted 30 September 2006 - 04:10 PM
VXJON: who did your custom exhaust? £400 sounds like a bargain. did you have to send the car in? I now have a whole spare cat + silencer so do you think its possible they could work off that while the car is kept on the road?
#37 VXJON
VXJON
  • 2,595 posts
Posted 30 September 2006 - 04:23 PM
It was msw in strathaven and the car was away for a day, dropped it off in the morning then picked it up later after work. Apart from the eml problem i would happily recommend msw to anyone looking at exhaust options for a vx thumbsup As i posted before the exhaust sounds exactly like i specified and with a wide range of tail pipes to finish it off you cant go wrongMSW
I will post up some pics of the installation on monday when i get it up on a ramp to fit the o2 sim
#38 2-20
2-20
  • 1,317 posts
Posted 30 September 2006 - 10:46 PM
MSW sells the Piper back box at £500.... not the place to buy from...
For your spacer, you can order it here:
http://www.voodooboo...s/O2_Simulator/
Basically, this device is made of 2 plug anti fouler but one is modified as shown here
http://www.s2ki.com/...59&hl=simulator
#39 oakmere
oakmere
  • 2,143 posts
Posted 21 November 2006 - 10:00 AM
VXJON Any developments with your engine management light problems? Did you try the O2 sensor spacer as suggested. I ask as I am thinking of fitting a sports cat. Cheers Oakmere
#40 VXJON
VXJON
  • 2,595 posts
Posted 23 November 2006 - 07:36 PM
Hi mate I didnt try the spacer i went for the universal sim which does work but also sets off a o2 heater circuit fault which means my eml is still on :( I havent had a chance to sort this out but i should be able to fix it by using a different 12v for the o2 circuit or by using a 30omh resistor across the ciruit to simulate a working heater :(
