Remove Gear Lever And Handbrake Surround
Posted 03 October 2006 - 08:16 AM
Posted 03 October 2006 - 08:39 AM
Posted 03 October 2006 - 09:27 AM
Posted 03 October 2006 - 10:28 AM
Thanks
Thats my saturday morning sorted then![]()
Would like to do mine , plus put a little extra sponge padding to give some comfort to the left knee.
Posted 05 October 2006 - 04:55 PM
Thanks
What did you cover your dash with and are you planning to use the same for the handbrake surround?
I've covered my door cards with blue alcantara and thought about the dash panel next (although it looks like it will be a very tight fit round the light switches).
Edited by johnboy_78, 05 October 2006 - 04:55 PM.
Posted 05 October 2006 - 05:15 PM
Yeah, you'll need to file/shave about 0.5mm off the top and bottom to clear the switches properlyWhat did you cover your dash with and are you planning to use the same for the handbrake surround?
Posted 09 October 2006 - 01:25 PM
Thanks for the tip!Yeah, you'll need to file/shave about 0.5mm off the top and bottom to clear the switches properly
On a seperate note, what are people using to stick the alcantara to the door cards/dash trim? I used liquid PVA for the door cards which worked ok on the big flat surface of the door card, but I reckon it will be a nightmare on the dash panels. Any suggestions on what adhesive to use??
John
Posted 09 October 2006 - 09:54 PM
