Geometry And Wheel Alignment
Posted 28 October 2006 - 08:20 AM
Posted 28 October 2006 - 09:27 AM
Posted 28 October 2006 - 02:16 PM
Posted 28 October 2006 - 05:16 PM
Posted 28 October 2006 - 06:17 PM
Posted 28 October 2006 - 06:43 PM
can geo setup be used to make the handling less "snappy" you know to increase the margin for error between facing the right and wrong way? Are the geo setups noticable on the road or more a track use focused mod?
Yes
Posted 29 October 2006 - 06:47 AM
Anybody know, how should I mean geometry data? For example toe-in documentation data is: "0.2mm; -0, +0.2mm"
Is it:
0.2mm nominal setup and tolerance -0 to +0.2mm from nominal setup
or
0 nominal setup and tolerance -0,2mm to +0.2mm?
I thing so the first choice, but my local geometry service mechanician told me that the second choice is correct?!?
I can't belive that because this notation: "data ; data , data" is not logical in second choice?
Greetings from Poland
Sebastian
Edited by Yoke, 29 October 2006 - 06:48 AM.
