Adjusting The Windows
46 replies to this topic
#21 SimonVxt
SimonVxt
  • 168 posts
Posted 30 July 2009 - 07:01 PM
Any ideas why mines looks different? trying to sort mine out... just 1 bolt in mine?
#22 TheStotts
TheStotts
  • 1,130 posts
Posted 30 July 2009 - 07:33 PM
:yeahthat: No second bolt on mine too.
Excellent guide by the way thumbsup
#23 dannynewport
dannynewport
  • 787 posts
  • Interests:Cars obviously. Train in MMA/Japanese Jiu Jitsu (More traditional style of BJJ), previously Karate, Ninjitsu & Krav Maga.
Posted 31 July 2009 - 09:33 AM
Mine had one bolt too...dont worry about it though.
Just loosen the bolt slightly & rotate the disc,tighten and close door gently with window up and check gap.
Seriously takes 2 mins to adjust.
chinky chinky
#24 TheStotts
TheStotts
  • 1,130 posts
Posted 31 July 2009 - 09:37 AM
chinky chinky
Cheers mate, had to put the door card back on as it started pissing it down. Will have another go at the weekend thumbsup
#25 DanFreemanPhoto
DanFreemanPhoto
  • 104 posts
Posted 05 September 2011 - 05:56 PM
Hi chaps, Just a had a go at this, mine too has just got the one bolt. What exactly is on the other side of the disc? what size bolt? I tried undoing it but failed, it would be good to know the right sizes though. Thanks.
#26 DanFreemanPhoto
DanFreemanPhoto
  • 104 posts
Posted 06 September 2011 - 07:12 AM
Could anyone help with this? With all this crappy weather coming, I really need to get this done. :)
#27 Stik
Stik
  • 174 posts
  • Interests:Cake
Posted 06 September 2011 - 05:21 PM
Hiya, on the other side is a small, quite flat bolt head, the thread you can see poking out of the disk is the end of it. 8 or 10mm, can't actually remember :) You just need to get a spanner behind it and fumble around for a bit Have you tried re-greasing the runners? Doing that solved most of my problems, turns out it wasn't lining up properly because the top of the front-most runner was all weird and sticky so it was bending the mechanism slightly when you wound it up and ending up slightly lop-sided. Might be worth doing that first, before you fiddle with all the alignment. Stick your arm in and have a feel, they're pretty much impossible to actually see unfortuantely It's a very satisfying moment when the thing finally lines up in the rubber groove on the roof :)
#28 DanFreemanPhoto
DanFreemanPhoto
  • 104 posts
Posted 06 September 2011 - 06:13 PM
Thanks Stik. I definitely need to adjust it, the previous owner told me he had adjusted it down (not sure why) I'll have another fumble next week sometime.
#29 DanFreemanPhoto
DanFreemanPhoto
  • 104 posts
If anyone knows exactly what size nut it is on the other side that would be a big help! None of the spanners I'm trying seems to fit lol!
#30 tone
tone
  • 114 posts
Posted 11 September 2011 - 12:07 AM
Think it's an 8mm :)
#31 DanFreemanPhoto
DanFreemanPhoto
  • 104 posts
Posted 11 September 2011 - 09:16 AM
Just managed to do it :) Thanks for all the help. Oh.....and it was 10mm :) (Well mine was anyway ;))
#32 petrolhead1
petrolhead1
  • 936 posts
  • Interests:Windsurfing and Sailing
    Karting
    My family
Posted 27 February 2012 - 06:58 PM
Passenger's side window is in need of serious attention. The glass is stuck in the fully up position. I dread to imagine what I may find when I start taking it apart. Vauxhall dealership has had this door off a couple of times to respray it under warranty so I dread to think what they have or have not left out of the re-assembly. I may take some pics as I get to the inside stuff which hasn't been covered before.
#33 Red 5
Red 5
  • 250 posts
Posted 30 June 2012 - 05:57 PM
...mine first car did this, its jumped the runner at the front because the screw at the top has un done causing the window to get jamed on it..
#34 Zuber
Zuber
  • 1,429 posts
  • Interests:Finding a way to motivate myself to get fit. Anything Interesting.
Posted 29 July 2013 - 06:03 PM
Anyone got some tips for removing the 'Play' from the whole thing. I've applied the trunking fix, but still get a rattle from the front runner wobbling.
I notice the screw into the front runner near the mirror goes into the groove. Is that normal ? I was thinking put a washer under it, but then it probably interferes with the glass.
#35 petrolhead1
petrolhead1
  • 936 posts
    Karting
    My family
Posted 22 December 2013 - 04:18 PM
Two posts above(almost 2 years ago) I mentioned my passenger window was stuck in the fully up position. We fixed it today.
I removed all the panels and then called in a friend for expert assistance. He had brought his special camera with an LED light on a bendy stick to help us look inside the door to try and trace what was wrong. It revealed nothing initially.
So we decided to remove the whole winder mechanism.
We also removed the little black trim panel at the front of the door which is held on with two plastic fasteners.
That was when we found the problem. There is a screw facing forwards near the top front of the door which had unwound itself enough to jam the glass. It required a screwdriver on a bendy drive to re-tighten it.
Reassembled, adjusted, checked the fit and it now works perfectly.
#36 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 30 December 2013 - 11:27 AM
I had the same problem when I got mine and followed this tip and now no more leaks.
#37 Cereal Killer
Cereal Killer
  • 81 posts
Posted 09 February 2014 - 05:18 PM
I'm trying to adjust my passenger side window following this guide and not having the best luck with it, I wonder if someone could help?
- The window sits right against the top seal (the one running along the softtop) at the back edge but at the front sits a bit low. I tried adjusting it but that bracket you tilt behind the two bolts (no.2 on the pic) is already at full tilt.
- Towards the rear, along the side of the window it isn't sitting against the rubber seal but at the top it sits against the other rubber seal (the one that's part of the softtop). I tried adjusting it inwards a bit with that screw at the bottom of the door (no.1 in the pic) but it didn't seem to do anything.
any help please.
#38 rizo9
rizo9
  • 533 posts
Posted 15 February 2014 - 06:23 PM
you need to adjust the overall height of the window, can't remember which adjust it was. then you can adjust the tilt.
#39 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 18 February 2014 - 11:07 PM
Use the tilt one to get it level. If the rear won't go up anymore on the tilt then just tilt the front down till its level. Then use the disc adjustment thing to allow the whole window to go higher now its level.
#40 Griffin
Griffin
  • 116 posts
Posted 11 November 2015 - 12:30 PM
Anyone have the missing pictures?
