Group buy went smoothly, and it came in the post yesterday
I've decided to document the installation in hope that it will encourage more people to get the system if they want it, and not be put off by the work involvolved, or the price of professional installation.
Have a read about the traction control here
At this point, I'd like to say that I'm not a professional mechanic in any way, and I have only been getting down and dirty with cars since I got my vx (about 3 months ago), but I do have more than a basic experience in electronics, and I like to think I have a good amout of common sense. Therefore, do this at your own risk!
Oblomov and Paul.Stuhlfelder have given me a lot of advice about installation which has been very useful. I have decided to go down a slightly different route to installation than they have, which will allow me to return the car to stock condition with the least amount of messing around if need be. I'll post their pms to me here (if thats ok with them), so you can look at it another way if you don't like my way.
I'm going to fit it over the next few nights and/or/maybe weekend if it takes that long. It's dark outside by the time I get home from work
Last night I read the instruction booklet and made sure I understood it all properly before I started installing it. I won't go into much detail about how it works (you can read a better explanation on the racelogic web site). Basically, you wire it in, stealing the signals from the abs system, the signals to the fuel injectors, and the RPM signal. If the system senses that the wheels aren't moving in sync, it will cut the signal going to the fuel injector, and the engine will do a controlled misfire to reduce power output momentarily.
This involves splicing the wires coming from the 4 abs sensors at the front of the car, at the ABS ECU, cutting the trigger signal to the 4 fuel injectors coming from the engine ECU, and wiring it (in series) with the RLTC control unit. The RPM signal, +12v ign are also spliced from the engine ECU, and the usual grounding points can be used for the neg.
If you didn't understand that, read more about it at the racelogic web site until you do.
Here we go then..
