A Race-speedster Is Born
419 replies to this topic
#381 dude
dude
  • 1,404 posts
Posted 29 September 2004 - 03:16 PM
a little racereport. short version: life sucks :( here´s the long version. saturday: after missing almost the whole qualifying because of a malfunction on the onboard-camera, we got it out for 3laps in the end. the car felt almost undriveble and after the session we remembered that the tirepressure was a bit high due to mounting on the rims. >35psi :D that explained why i had some problem with oversteer. still i managed to qualify in 2:nd place in the class and a 18:th of 36 starting. we agreed to start from the pit because we were shooting (did this for a tvchannel called viasat sport) with a camera just behind the right frontwheel (they didn´t want a smashed one in return), so i did about 10 laps and returned to pit for a change of driver and relocating of the camera. stefan got out and stayed for an hour before switching to helena. i took the last stint and when it was 20min left, the car died in righthand turns, so i decided to get into the pit and try to locate the problem. we didn´t find anything that could have caused this, so we just had to let it be and try to sort it during the 8h-race on sunday. sunday: when we unloaded the car sunday, we saw that we had a hugh crack in the frame over the right toelink (didn´t i read about that somewhere :rolleyes: ) we decided not to race and instead do a proper repair at home. this was the last race for the year and we have already started to disassembly the car for some mayor upgrading for next season. i´ll keep you updated.
Edited by dude, 29 September 2004 - 03:17 PM.
#382 Turbo Head
Turbo Head
  • 1,805 posts
Posted 29 September 2004 - 03:39 PM
Shame :( Better luck for next year, Anders, keep us posted. thumbsup
#383 clipping_point
clipping_point
  • 4,908 posts
Posted 29 September 2004 - 04:44 PM
:o Last race? Thought there was one race remaining at Mantorp Park around mid Octobre?? Was really looking forward to that :(
#384 dude
dude
  • 1,404 posts
Posted 29 September 2004 - 05:38 PM
your right about the race, but we will not participate there :( . it´s not a cheap hobby we´re stuck with :D usually it´s snowing and subzero (this made our choice easier) on the finals and i don´t have any longstockings to keep me warm thumbsup
#385 magic_speedster
magic_speedster
  • 12 posts
Posted 17 January 2005 - 04:31 PM
some updates.
the engine is in place and everything except the ecu with harness is ready.
Hi Anders,
I have a short question. Is the engine in its original place or did you move/tilt it back to be able to fit the intake manifold and the 100l's tank?
#386 dude
dude
  • 1,404 posts
Posted 17 January 2005 - 11:09 PM
not tilted or moved thumbsup
#387 clipping_point
clipping_point
  • 4,908 posts
Posted 18 January 2005 - 08:58 AM
Tilting the engine can lower the CGH. I think they did it on the ColinBlower thingy! thumbsup
#388 dude
dude
  • 1,404 posts
Posted 18 January 2005 - 11:49 AM
colin could do that because he uses a quaife(hewland/xtrac etc) gearbox that allowes it. i don´t think a tilt of the std-engine would change the cgh at all.
#389 NOEXCESSBAGGAGE
NOEXCESSBAGGAGE
  • 690 posts
Posted 20 January 2005 - 10:09 AM
It should, cuase you are lowering the height at which the Centre of Mass of the engine is established by the factory build.
#390 dude
dude
  • 1,404 posts
Posted 20 January 2005 - 02:51 PM
well theoretical maybe, but the engine can´t be tilted more than maybe 5cm on a std-car. on my racecar i could probably tilt it backwards(not forward), but that would create weighttransfer to the back thumbsdown
#391 dude
dude
  • 1,404 posts
Posted 20 January 2005 - 02:58 PM
the mass-center of the engine would be approx. about 8-10cm over the center of the crank. tilting the engine 2-3degree (~5cm at head) would change the cgh of the engine about 3mm. a lot of work and almost no gain?.
#392 NOEXCESSBAGGAGE
NOEXCESSBAGGAGE
  • 690 posts
Posted 20 January 2005 - 07:35 PM
...a lot of work and almost no gain?.....
On the face of it, probably a heck of a lot of work for little gain.
It is difficult to say however without having figures for the car realting to its original longitudinal and transverse and vertical centres of gravity.
You'll then need an accurate mass figure for the engine, and find out where the centre of gravity of the engine act (or its position).
You then have to create a table of moments from the shift in position (yeah, complicated thumbsdown ) to the new centre of gravity, i.e. GG1
In reality my gut feeling is that although you've managed to lower the centre of gravity of the car - through a considerable amount of effort ;) - you'll have moved the centre of gravity towards the rear of the car, in one foul sweep.
This will have the beneficial effect of improving your cornering powers, but the detrimental effect of increasing the car's polar moments of inertia.
And it's the polar moments of inertia you really want to be keeping as low as possible, which translate into instantaneous response.
#393 dude
dude
  • 1,404 posts
Posted 06 June 2005 - 12:48 PM
Fired up the new engine last night and the running has started and mapping will begin later this week :groupjump: it´s a whole different sound and it´s mean B) B)
#394 Nikov
Nikov
  • 723 posts
Posted 06 June 2005 - 01:35 PM
Hi Anders, did you get your Quaife LSD and if so what do you think of it? Rest of cars looks great thumbsup thumbsup .
#395 dude
dude
  • 1,404 posts
Posted 06 June 2005 - 01:55 PM
no i haven´t.
graham said they were going to be shipped last tuesday, but haven´t seen or heard anything about them since.
#396 dude
dude
  • 1,404 posts
Posted 22 July 2005 - 12:15 PM
good and bad news :rolleyes: we started mapping today and ended mapping when a rollerrocker nearly past through the side of the cylinderhead. we haven´t determent what the cause was, but probably a hydraulic lifter that has started the mess.
#397 csl_freak
csl_freak
  • 98 posts
Posted 23 November 2005 - 06:10 PM
So Anders, whats the latest on you luvly car ?
#398 JayK
JayK
  • 1,141 posts
Posted 23 November 2005 - 07:03 PM
Just read all of this thread, now im going to sleep! :D Excellent Work! Jay
#399 dude
dude
  • 1,404 posts
Posted 09 December 2005 - 09:15 PM
I have started to work on the car after a long break. I lost all my devotion and joy to work on the car after the engine breakdown in midsummer. But i´m back and i´m going to beat the sh*t out of this crappy car and race it like it never been raced before :D The new thing is that our raceclass has got unlimited wheelwidth. I ordered 8 new 8x17" Superleggera and a set with 2 x 8x18 and 2 x 9x18". Tiresize will be altered depending on track, but 215/45-17 and 255/40-17 or 225/40-18 and 265/35-18 is two options.
Edited by dude, 09 December 2005 - 09:16 PM.
#400 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 09 December 2005 - 09:31 PM
:o make sure you post some pics of those configurations
