A Race-speedster Is Born
#121
Posted 11 January 2004 - 01:05 PM
#122
Posted 11 January 2004 - 01:18 PM
#123
Posted 11 January 2004 - 02:02 PM
I suspect he likes his job....this is stefan. who is the best teammate one can want.
he has done about 150hours on the car under his christmas holiday from work (3 weeks).
#124
Posted 15 January 2004 - 07:57 AM
#125
Posted 15 January 2004 - 08:03 AM
#126
Posted 15 January 2004 - 05:22 PM
#127
Posted 15 January 2004 - 05:36 PM
#128
Posted 15 January 2004 - 05:41 PM
the white stuff on the frontclam is ordinary 2k paint. it´s there to make a good surface to wax on so the moulds won´t get stuck.Hi Anders,
what is the white stuff on the speedster clam? teflon sheet?
being made ON TOP of the original, won't it result bigger than the original?
how much weight do you predict to save on each clam?
the black part you see is the negative mould that i´m using to create the parts that´s going to be used on the car.
the final parts will be an exact copy of the frontclam as it looks.
every miss i made in the finish of the car will show exactly the same on every copy.
i will post pics during the making of these parts. but it will take 2-3 weeks because the moulds have to rest an harden out before we can use them.
the complete frontclam incl bonnet (and inside part of bonnet) is approx 8-10kg in regular fiberglass with polyester.
if we get the time to use vacuumbaging with fiberglass rowings and epoxi the weight should stop around 5-6kg.
i will put out the exact weight when the parts is ready.
#129
Posted 15 January 2004 - 05:42 PM
doh, right.....he's making molds isn't he. Then it will be the same size!
#130
Posted 15 January 2004 - 05:44 PM
...so how much do you foresee for the rear shell, that I weighted stock at 28 kg?
edited to say 28+7kg from the stock bootlid, that you will have included in the clam, if I understood right...
Edited by Ricky2772, 15 January 2004 - 05:53 PM.
#131
Posted 15 January 2004 - 09:07 PM
#132
Posted 24 January 2004 - 08:25 PM
#133
Posted 24 January 2004 - 08:27 PM
#134
Posted 24 January 2004 - 08:29 PM
#135
Posted 24 January 2004 - 08:32 PM
#136
Posted 24 January 2004 - 08:56 PM
#137
Posted 25 January 2004 - 10:53 AM
...will you employ some sort of mesh air-filter at the end of the pipes, or you'll go for .... bugs'n dust power mix?!?
We know your wife loves you, she wants everybody to know...
http://www.patrick.f.....?text=Anders!
Edited by Ricky2772, 25 January 2004 - 10:57 AM.
#138
Posted 25 January 2004 - 01:23 PM
well! i hope to catch some small birds and a occasional squirrel for dinner at the races. i have to cut cost to drive my babiecool....
We know your wife loves you, she wants everybody to know...![]()
btw where did you find a pic of my wife
i will put a plenumchamber over the runners and have a single 75mm throttlebody.
if we find the time, there will be a airscoop above the roof for fresh cold air, slightly pressureised by speed.
a little like the lmp-cars at lemans.
//anders
#139
Posted 28 January 2004 - 09:49 AM
#140
Posted 28 January 2004 - 11:05 PM
