Vgt - Variable Geometry Turbos
#21
Posted 03 January 2007 - 08:36 PM
#22
Posted 03 January 2007 - 11:41 PM
Rob
I work at Trucast and supply Holset with the turbine wheel! Small world ehh!
In my limited experience the design of the Holset (Cummins) VG seems much simpler (cheaper??) than the BorgWarner/ Honeywell design. How do the two differing designs compare in terms of performance? Is the design difference due to the exhaust temperature differences?
Mike
The BorgWarner system appears to be using special areospace materials in it's construction. It must be a design specific for Porsche's requirements (else BW would let their distributors sell it, no?) If anybody could get the specs and a compressor map on the unit too that be great!
Edited by speedster, 03 January 2007 - 11:42 PM.
#23
Posted 04 January 2007 - 11:14 AM
The compressor map would be 3d, wouldn't it for a VGT turbo? Sounds like fun trying to read that!
#24
Posted 04 January 2007 - 12:44 PM
No the compressor stage is the same as a fixed geo turbine, as that would be a VGC
The turbine map however does change with the position so is mapped as 2d maps at steps through the range of movement, this can then be represented in 3d (but nobody can be arsed writing the software). These maps are then use in engine simulations such as GT power that interpolated between the maps at a give %open.
However there are simplified method of looking at the results.
#25
Posted 04 January 2007 - 05:56 PM
Which as it's originally for a 2.3 engine is more likely to have a compressor stage that will match the engine breathing of the VX 2.2 engine.
We're not sure who makes the turbo, but the best guess is IHI.
#26
Posted 04 January 2007 - 08:27 PM
Have a look here if you are interested in knowing more....thats me BTW driving the car!
http://www.ricardo.c...i_rqarticle.pdf
#27
Posted 04 January 2007 - 08:41 PM
After a chat with a few people at work I found this, clicky, the only other petrol VGT application.
on further investigation it looks like this uses an actuated waste gate to change the flow through the turbo, not a vgt.
The one i was thinking of was the Mitsi.
Edited by Winstar, 04 January 2007 - 08:44 PM.
#28
Posted 04 January 2007 - 10:40 PM
I work for Ricardo and we developed a demonstrator vehicle called LBGDI (Lean Boost Gasoline Direction Injection). The car was a Ford Focus and we used a 1.1litre 3 cylinder engine, running lean with a VGT. We were able to use a diesel VGT for this application since the exhaust temperatures were lower.
Interesting... Do you know how the VGT was managed? I assume you had to acquire a specialised engine management system.
Found this on ebay
CLICKY
#29
Posted 04 January 2007 - 11:08 PM
#30
Posted 04 January 2007 - 11:30 PM
[quote name='johnaachen' post='540263' date='Jan 4 2007, 20:27 ']
[/quote]
I dont think that I am allowed to say who supplied the ECU. The strategy was written by ourselves, well partly me actually
The VGT was driven using CAN via a REA smart actuator. Garrett VGT.
HTH
Who do you work for then?!
#31
Posted 05 January 2007 - 12:04 AM
I dont think that I am allowed to say who supplied the ECU. The strategy was written by ourselves, well partly me actuallyand involved some addtional hardware used to bypass software in ECU. We wrote our own strategy using Ascet-SD and this was running on an ES1000 - mean anything to you? The lambda control strategy was also bypassed on the ECU and we wrote our own strategy again.
HTH
I take it that's the prototyping tool from ETAS? I can across it when I was looking for a standalone ETB driver but it's way out of my league.
Me, I don't work in the auto industry. I am just looking into this for my own engine design.
Did you just run this prototype on petrol?
#32
Posted 05 January 2007 - 12:15 AM
#33
Posted 05 January 2007 - 12:43 AM
#34
Posted 05 January 2007 - 09:13 AM
ETB - Electronic Throttle Body...
Software ain't a problem, that's my field of study!![]()
Can you get me your test rig sensor input figures with matching VGT behaviours (including boost vaules).![]()
What AFR were you running lean at? I'm interested in bioethanol however I've been told to expect a 30% increase in consumption when boosting for big power....
I couldn't give you any test bed data I am afraid -it would be client confidential. I know that we ran up to lambda=1.4. When boosting you need to hose in more fuel to cool down the turbo....well that was my understanding of it anyway:-)
#35
Posted 05 January 2007 - 01:22 PM
#36
Posted 10 January 2007 - 06:36 AM
#37
Posted 10 January 2007 - 01:04 PM
Turbo Tech 101 ( Basic )
Turbo Systems 102 (Advanced)
Turbo Tech 103 (Expert)
I expect you'll only need to look at the Tech 103, however there's some good stuff on compression ratio and AFR in 102, the rest gives a good guide to turbocharing. Thery're from the Garrett website but quite good info, although IMO not enough to match a turbo to an engine.
Rob
Edited by Winstar, 10 January 2007 - 01:10 PM.
#38
Posted 11 January 2007 - 08:28 PM
#39
Posted 11 January 2007 - 09:39 PM
Edited by Winstar, 11 January 2007 - 09:39 PM.
#40
Posted 11 January 2007 - 11:52 PM
