HERE...and HERE (2)
I'm in a real quandry. Which one do I go for? TMS or Courtenay (or AN Other?). Here's what I understand so far (bear with me as my technical understanding of this is very limited):
The nature of available cooling to the mid-mounted Z20LET engine means it is susceptible to high inlet air temperatures. This is less relevant to fast road use and mainly affects cars used on trackdays. I have experienced this, particularly on hot days, when the ECU pegs back boost 3/4 laps into a session. Also, I am wondering whether some of the AMM replacements I have required, were caused by excessive heat build-up on trackdays (is this possible?). So, as well as reducing inlet temps in order to access sustainable power on trackdays, it's really important to me to know that heat soak / general cooling is as good as it can be on the car.
So, as I use the VX for in the main, trackdays, it would make sense to invest in a c/cooler upgrade. Looking at the available options, here's how I see it:
TMS Chargecooler
- Retains std intercooler, adds Chargecooler system. Additional weight implications(?)
- Reduces inlet temps by c30%
+ve: All my tuning work has been done by TMS already therefore any remap I need post-c/cooler fitment is FoC.
+ve: TMS within 1 hour from home to cure any minor glitches post fitment.
COURTENAY Chargecooler
- Removes entire intercooler system.
+ve: Reduces intake temps by 40%. Courtenay website claims: "On a car running at 240 bhp we dropped the temp from 73 to 34 degrees"
+ve: Weight gains are neglible as i/c system is completely removed.
+ve: Intercooler ducting is completely removed, enabling better engine cooling all-round.
-ve for me: All my tuning so far has been carried out by TMS. I guess I would lose any warranty I would have with them and any remap I would require, post-chargecooler fitment, would cost extra (?). Also, John would you still speak to me ?
HOWEVER - just picked up on courtenay's website that: "Our CS1, CS 2, CS 3 and CS 4 Tuning Packages now include a Rolling Road Session optimising fuelling, ignition and boost maps. All our prices include VAT."
-ve: Courteny are ferkin' miles away (3-4hr drive).
So...I'm not sure which way to go. Based on the limited technical knowledge I have gleaned, the Courtenay option appears to be best suited to my needs, based on the fact that charge-cooling is more efficient for the same given size. So, for the limitations on surface area cooling in the VX, this would make sense, no? <scratches head>
