Balance Shafts
30 replies to this topic
#21 luna_s
luna_s
  • 1,934 posts
Posted 20 April 2007 - 12:29 PM
heh,
the chain is similar to this,
i suppose a motorbike shop or something might fix it, but for reliabilty i'd stick with the standard length.
#22 Steve Crisp
Steve Crisp
  • 1,810 posts
  • Interests:VX220's...
Posted 20 April 2007 - 12:58 PM
You're getting oil on your carpet! If that's the style of chain, then it will shorten reliably with a fly-press and punch. What you have there was probably caused by a seizure - something stopped turning and the drive ripped the link apart! Done properly (I guess this is where you're coming from), it'll be as strong as standard. ;) Steve
#23 vocky
Posted 20 April 2007 - 01:15 PM
A pin-punch will generally allow chains to be shortened without a split-link. I must look at the old chain I have in the garage.
I thought Vocky was Keith? I thought he'd be the one to answer! No offence intended... :D
Steve
I'm not keith either :lol:
you cannot shorten the water pump chain, it has to follow the route designed by GM, otherwise I would have shortened it, it's very easy to do with a chain tool :)
#24 chris
chris
  • 524 posts
Posted 20 April 2007 - 02:49 PM
Steve
You could install cooling electric pump ?
:dry:
#25 Steve Crisp
Steve Crisp
  • 1,810 posts
Posted 20 April 2007 - 04:10 PM
That's fine. The fact that you thought about it is enough for me - if you could have done it, you would have. Who the f*ck's Keither then? I picked it up form somewhere... :beat: Steve
#26 Steve Crisp
Steve Crisp
  • 1,810 posts
Posted 20 April 2007 - 04:32 PM
#27 luna_s
luna_s
  • 1,934 posts
Posted 20 April 2007 - 06:55 PM
dunno - i'm mark :P
no electric pump, apparently not reliable enough for daily use?
I was going to go down that route
chain damage is down to stretching due to oil starvation (blocked nozzle) this is what happens kids when the old nozzle gets blocked :D :angry:
oh its not me carpet, thats the drive, however my kitchen lino is looking very sorry for itself at the mo :P
*actually tidied since.............
Edited by luna_s, 20 April 2007 - 06:56 PM.
#28 alanoo
alanoo
  • 1,324 posts
Posted 20 April 2007 - 08:47 PM
Hey, could you try to take a pic of the place for the oil cooling jets ? Apparently they are easily visible as they are cast even on our blocks ? Imnotworthy
#29 luna_s
luna_s
  • 1,934 posts
Posted 20 April 2007 - 08:59 PM
i can't now sorry, blocks at the engine place getting a rebore, plus bits fitted for me i checked for the location of the jets after removing the shells but couldnt immediately see anything, - would still need machining, maybe vocky could be so kind, hes got a spare block i beleive :P
#30 Steve Crisp
Steve Crisp
  • 1,810 posts
Posted 20 April 2007 - 09:00 PM
You've got a rather posh drive Mark, and I can't see anything wrong with your kitchen - the decor is fine! :blink: Steve
#31 vocky
Posted 21 April 2007 - 12:44 AM
pistons 1+4 have the casting, 2+3 don't :blink:
but the oil supply to the bearings runs in a slot, so fitting oil cooling jets would be very easy - just drill a hole and fit the oil jet :)
sixth pic down in this thread z22se
